Wiper arm restoration, and seafoam
Old July 15th, 2011, 07:17 PM   #1
Run ur car, not ur mouth.
SON1C's Avatar
2003 Sonic Blue 4.6L
SON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of light
Thoughts and opinions on seafoam?
for wiper arm resto, i picked up satin black krylon and 180 grit and 1000 grit sandpaper, should be fine?
how should i go about doing that
been super busy lately any breaking news i've missed?
side note prefilling oil filter? thoughts?
another side note switching from 5w-30 to 5w-20?
238rwhp/263rwtq
Drew's Build Thread
Old July 15th, 2011, 07:48 PM   #2
lol....you have alot of questions
how do you want to use the seafoam? through the intake...in the crankcase...gastank?
as for wiper arms..
1. remove
2. scuff
3. paint
4. dry
5. install
oil weight...
ford calls for 5w20..it's what i use but then again i like to keep things simple
Old July 15th, 2011, 07:53 PM   #3
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
RedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really nice
I'm sure once McQueen gets in here he'll be able to give you a great answer about painting your wiper arms
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok.
05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel
Old July 15th, 2011, 08:01 PM   #4
Dancing Naked In The Rain
mcqueen's Avatar
For the painting, wiper arms are easy. Take them off, scuff them with your low grit sandpaper, scuff them with your high grit sandpaper (180 might leave some grooves, the 1000 will take care of that), clean them, spray them (no need for primer on these or clear on these), let them dry, reinstall them.
For the Seafoam. I'm starting to think that it doesn't work as well as I used to think. If you're going to do it, just get the B12 or whatever the "off brand seafoam" is called. Now here's why I don't think Seafoam works as well as I used to think.
This is my upper intake, 10k miles after Seafoaming
Swipe my finger through it and I get this
Lower intake, again after 10k miles
Stuck my finger in there too
So either my engine forces a ton of oil through my PCV line and into the intakes, or Seafoaming isn't the super cleaner I believed it was.
You're so sweet Matt
My Hubpages
Hey.. r u really a tranny??
Old July 15th, 2011, 08:09 PM   #5
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
Anything for you Queensy......Anything
Old July 15th, 2011, 08:17 PM   #6
Skar Gone
Skargon's Avatar
1998 Mustang V6
17.27@76.66
Skargon will become famous soon enoughSkargon will become famous soon enough
Aww, I was planning on Seafoaming soon. Now I'm afraid of wasting money. Lol
Was gonna do 1/3 Gas
1/3 Intake, and 1/3 Oil.
"But the Oil would wait untill the next oil change so I can do it about a week before the Change." I've heard its bad to keep it in the oil?
1998 5 Speed, CAI, Exhaust, Rear Seat Delete.
Old July 15th, 2011, 08:37 PM   #7
mcqueen's Avatar
Seafoam is usually about $10 for a can. There's an off brand called B12 or something like that and it's only $3-4 for a can the same size. 1/3 gas, 1/3 oil, 1/3 intake is what we normally do. The gas is optional but it is good for the fuel system so I recommend it (Seafoam was originally developed as a fuel system cleaner). And I wouldn't leave the Seafoam in the oil for more than a few days. It is some pretty potent stuff and will eventually start eating through gaskets and seals. I would put it in 2 or 3 days max before you change the oil. I know people have left it in longer but the longer it's in there the more you risk it going from cleaning to damaging.
My Hubpages
Old July 15th, 2011, 08:47 PM   #8
Skar Gone
Skargon's Avatar
1998 Mustang V6
17.27@76.66
Well McQueen; That doesn't sound gewd.
How exactly do I put it into my intake?
Squirt it into the Throttle body while the engines runnin?
Or is their a smarter way?
Old July 15th, 2011, 08:47 PM   #9
or he can just read what i posted on it...since McQueens answer was just a longer version of what i just said bwahahaha
Old July 15th, 2011, 08:53 PM   #10
mcqueen's Avatar
Pull the PCV line off the the driver side valve cover while the engine is running, have 1/3 of the can of Seafoam in a cup, and put the PCV line right down next to the Seafoam. Don't dunk it in or the engine will stall, just let it slowly suck it in (the engine creates a vacuum after the throttle body and it should be strong enough to suck the liquid in if the PCV line is within a few millimeters of the Seafoam). Some people will tell you to use the brake booster line but don't listen to that, it only feeds a few of the intake runners and you want it to get to all of the runners.
I like using more words
My Hubpages
Old July 15th, 2011, 08:54 PM   #11
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
Lol sorry dude, I wasn't meaning to be condescending or anything like that.
Old July 15th, 2011, 09:08 PM   #12
its all good
Old July 15th, 2011, 09:16 PM   #13
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
If I recall correctly our drivers side valve cover has a problem with allowing oil through the PCV valve into our intake. This was fixed with a different valve cover in 01+ or you can modify the inside of the cover itself.
Here's some more info on it if you're interested. My upper intake looked pretty much the same when I last had it off.
99-00 3.8L Mustang Driver's Side Valve Cover Fix
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old July 15th, 2011, 10:31 PM   #14
mcqueen's Avatar
That is some very useful info, repped. I'm going to have to get an 01+ valve cover for the driver side when I put my engine back together or drop in a new engine.
My Hubpages
Old July 16th, 2011, 10:06 AM   #15
SON1C's Avatar
thanks,
and i've seafoamed before just kind of forget
1/3 into a full tank of gas otw to wherever to put 1/3 into pvc while engine is nice and warm, let it set for 15, also add 1/3 into oil, take it for a high revving drive, come back, change oil
done.
and any tips on spray canning, i don't have much experience with them just try to maintain same distance, spray even, start before item and end after item for even coat?
238rwhp/263rwtq
Drew's Build Thread
Old July 16th, 2011, 12:38 PM   #16
bluesmokesixxer's Avatar
2002 Mustang 3.8L
bluesmokesixxer will become famous soon enough
thanks,
done.
Yup sounds about right, pretty much what I did. Smoke Show
Yeah painting your wiper arms should not be too hard to make look good, just even coats.
Oh and hey Drew, haven't seen you on in a while
"Quit Bitchin' and drop the clutch"
Old July 16th, 2011, 12:47 PM   #17
mcqueen's Avatar
thanks,
done.
All of that is correct. If you want more detailed info about rattle can painting, there's a link in my sig to a write-up I did.
My Hubpages
Old July 16th, 2011, 04:57 PM   #18
spaseghost's Avatar
It makes my wife horny
16.3@84@5kft
spaseghost is on a distinguished road
maybe i over do it, but i do a whole bottle of seafom through the intake, then a half in the oil and gas tank. i let it sit over night usually on a weekend and go flog the shit out of it the next day then change the oil. Its held up for the 40000 miles ive put on it doing that and it runs great.
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k
1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21
2004 Nissan Armada - HIDs, LEDs, sippy and DVDs
2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
Old July 16th, 2011, 07:15 PM   #19
SON1C's Avatar
mcqueen what happened to your engine? i missed it, last time i was really on was the whole garage fire ordeal
and lol yeah andrew i havent been on really this month, busy etc, you know how it is, and if you want to take part in the smokeout just lemme know
238rwhp/263rwtq
Drew's Build Thread
Old July 17th, 2011, 02:34 AM   #20
4U2C is on a distinguished road
uhm i thought that oil was from your kn filter as you stated in my thread? figured it was bs just to discredit kn..lol
Threads Similar to: Wiper arm restoration, and seafoam
Headlight Restoration NoColoradoGT General Car Care & Detailing 2 March 28th, 2011 12:18 AM
Seat restoration MRKsD3 Visual 3 March 13th, 2011 11:45 AM
restoration chickenbot 5.0 Mustangs 3 January 16th, 2009 11:40 AM
The restoration of my baby MSO The Clubhouse 39 June 11th, 2007 10:09 PM
Restoration DanHurley99 Classic Mustangs 5 March 4th, 2007 02:58 PM
