A/C cutting in/out
Old July 18th, 2011, 03:46 PM   #1
kingcudi's Avatar
2000 Mustang V6 3.8L
kingcudi is on a distinguished road
A/C cutting in/out
guys my a/c has been cutting in and out a lot recently..still blows cold but when I get into the gas a little bit more than chill it blows warmer, and randomly/often when i'm cruising at a constant speed. my friend said it could be the vent check valve but i am unsure, Mattman said it could be the a/c clutch but its fine at idle, and can't check it when I'm driving..
help?
Old July 18th, 2011, 03:51 PM   #2
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
I would think that it's either a AC clutch or compressor problem.
I'm really not sure how to test that while you're driving though. Can you get it to do that while revved and not moving?
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old July 18th, 2011, 03:52 PM   #3
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
a/c delete kit, simple fix.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old July 18th, 2011, 04:01 PM   #4
kingcudi's Avatar
I looked at the clutch while revving it on the throttle body and it didnt stop spinning, so how am I to check the compressor for problems?
Old July 18th, 2011, 04:23 PM   #5
Well your AC should cycle.. so you should see the clutch catch and release.
Old July 18th, 2011, 04:36 PM   #6
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
you could be low on freon....
MM Cobra Club #25 My Autolog Profile
Old July 18th, 2011, 05:11 PM   #7
kingcudi's Avatar
Is it supposed to turn on and off a few times a minute? From what i noticed it didn't release while the air was on until I jumped the low pressure switch on the canister so I could keep the compressor running while I checked the freon pressure..its sitting at 37psi. The first time I jumped it it released but I tried it again and the clutch stayed engaged..idk what else to look for
Old July 18th, 2011, 05:21 PM   #8
Green_6er's Avatar
2000 Mustang 3.8
maybe just need a compressor rebuild
Old July 19th, 2011, 11:53 AM   #9
kingcudi's Avatar
is that something I could do myself?
Old July 19th, 2011, 12:34 PM   #10
Green_6er's Avatar
2000 Mustang 3.8
you have to get the freon evacuated first (go to a shop) then u can.
Threads Similar to: A/C cutting in/out
95' GT cutting out 4k rpm LXstang5.0 94-95 18 August 29th, 2009 10:00 AM
car cutting off 94mustang94 94-95 9 August 23rd, 2009 01:13 PM
Cutting Out Illuminator 5.0 Mustangs 2 November 13th, 2007 10:45 AM
car cutting out..please help 89LX347 5.0 Mustangs 12 June 4th, 2007 06:53 PM
Car Is Cutting Out! Help! streetstang06 96-98 10 September 14th, 2006 08:17 PM
