What Manual Transmission is best for power?
Old July 19th, 2011, 12:31 AM   #1
Loki's Avatar
1996 V6
Loki will become famous soon enough
I am wondering what transmission people use when they go FI, whether it be via turbo or SC. I'm going to replace my driveshaft soon to try and get rid of some vibration. I'm thinking that if I may have to swap out my transmission for something stronger in the future, maybe I should look into it now before I spend money. Do you guys suggest the t5 our cars came with or is there a better option that will mate? Or maybe just re-building the stock transmission? I haven't seen much info on the subject..
Old July 19th, 2011, 12:46 AM   #2
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
dog tooth t5
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old July 19th, 2011, 01:06 AM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
T56, though I've never seen one adapted to a 3.8L.
I think if you want to stay sticky, you'll have to go with a built T5, as I don't know of any other options.
O o
/¯/______________________
\_\
Old July 19th, 2011, 01:13 AM   #4
Loki's Avatar
1996 V6
That's what I thought, but wanted to make sure. It doesn't look like I'll have any problems then!
I kind of wish a T-56 would mate up, though That'd be pretty cool. Lol
Old July 19th, 2011, 02:35 AM   #5
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
T-56 Does mate up to the 3.8
ive heard you need to buy the bellhousing made to mate the t56 to a 5.0 and it should work.
2004 Bolt on & Cammed 3.9L V6
Old July 19th, 2011, 03:41 AM   #6
Loki's Avatar
1996 V6
^ Really? I'm going to have to look into that a bit more. It would definitely be a bit stronger than the t5, I would think.. Do you have any info on it? Google might be my friend here. lol
I was either going to replace my ds with an aluminum one from AM or an oem. I might still do so.
Old July 19th, 2011, 09:32 AM   #7
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
I had seen somewhere that the V6 uses the 5.0 style bolt pattern for the transmission. Makes sense since both use the T5.
And there are plenty of T56 swaps for fox bodies. Trust me, when I was looking for a Cobra swap it was infuriating to see how many swaps there were for fox bodies, but none for new edges.
Then the question would be shifter location. I don't know if the RFOB (Rear Face of Block) plane is the same for the V6 and V8. I know for trucks with multiple engine platforms it's common OEM practice to use the same RFOB plane for ease of integration. Not sure if Ford followed suit. If not, what's a hole in your console?
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old July 19th, 2011, 09:36 AM   #8
Not necessarily, the T5 is in incredibly common transmission, and was used behind the 2.3L as well as in the Camaro, S10, 240SX, hardbody pickup, and 300ZX as well. Doesn't mean that all versions share mating surfaces.
O o
\_\
Old July 19th, 2011, 09:44 AM   #9
MM's king of Neon's
404 - car not found
17.81@87
True, same as the difference in bolt patterns for the T56 between Ford, Dodge, GM...
But it certainly would be an odd move on Ford's part to use different bolt patterns for different engines but the same transmission. Of course I'm thinking from an engine manufacturer's standpoint. We use the same bolt pattern (though it's a specific flywheel housing option) across similar engine families to mate to the same transmission. (ie ISL-9 and ISX-11.9 using the Allison 3000HS) Can't say it's common practice though.
Old July 19th, 2011, 12:15 PM   #10
Loki's Avatar
1996 V6
It's just something I'd have to look into. Also, I DO NOT have a new edge. My Mustang is a '96. Though I think everything is aligned the same in that direction. I think the New Edges are just a bit wider on the body.
What about the advantages of the t-56? It could definitely hold more power. I'm also assuming it would get better gas mileage (Depending on how hard you drive ) Also, I think our t5's are 28 spline as opposed to the t56 being 31. It was too late to do research last night, but I'm going to look into it now that I have a few extra hours. I'll keep you guys posted on what I find!
Old July 19th, 2011, 12:27 PM   #11
MM's king of Neon's
404 - car not found
17.81@87
T56 is stock 10 spline, or aftermarket 26 spline. Mine's a 26. Personally I just got it for the strength. There's a member on here with a twin screw Cobra putting around 650 ft-lb though it and it's holding up well.
I wouldn't cite better fuel economy. It's similar to the T3650, except that it's 5th gear splits the huge gap between the T3650's 4th and 5th gear. Otherwise 1-4 match up pretty closely, and 5 and 6 are similar. Possibly if you do a lot of driving in the ~40-50mph range you could save some fuel economy, but it would be very dependant on duty cycle.
Old July 19th, 2011, 12:42 PM   #12
Loki's Avatar
1996 V6
Honestly, the more I look into it, the more I think I'd rather just stick with the t-5. There's much more out there for beefing up a t-5 and having no problem putting it in our cars. I can't find a single "fact" about using a t-56. Overall, I think this was just something that crossed my mind and I'm chalking it up as a no-go. I appreciate the help, though. (I think I'm going to keep searching just so I have more info on the subject for the future..)
Old July 19th, 2011, 05:59 PM   #13
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
World Class T5; had a bud with a nice built 5.0 using a WC and it never had issues.
Threads Similar to: What Manual Transmission is best for power?
new to a manual transmission Everett 99-04 7 November 11th, 2010 02:50 PM
What manual transmission to go with? stealthstang 5.0 Mustangs 5 May 14th, 2010 06:17 PM
Manual Transmission 88mstang 5.0 Mustangs 0 November 12th, 2007 11:47 AM
Manual Transmission Fluid lwhitetrash88l V6 Mustangs 17 August 29th, 2007 09:55 PM
www.manual-transmission.com 1gunner23 Vendors 0 June 16th, 2006 06:14 PM
