Replacing aftermarket springs
Old July 19th, 2011, 12:57 AM   #1
Tcohoe's Avatar
Tcohoe is on a distinguished road
Going tomorrow to replace my eibach pro street springs ( i have the whole kit currently installed) and i have a couple questions. Reason for changing is mostly to increase the ride height, it is wayyy to low for my gravel roads
1. Can i install the factory springs even though i have aftermarket shocks etc?
2. Gt or v6 springs? i know that the gt will raise it a bit more than v6
Thanks for the help, nothings worse than hearing your car scrape the ground
Old July 19th, 2011, 01:00 AM   #2
factory springs will be fine....both GT and v6 springs will do the job...although to make it still look good and be higher then your current kit...cut a coil off of each spring then install it with the isolators...average drop then is around an inch
Old July 19th, 2011, 01:08 AM   #3
Tcohoe's Avatar
thanks
Old July 19th, 2011, 01:09 AM   #4
np...where are you located btw?
Old July 19th, 2011, 01:17 AM   #5
Tcohoe's Avatar
Near Winnipeg, Manitoba
Old July 19th, 2011, 01:18 AM   #6
well welcome to the site....good luck with the swap
Threads Similar to: Replacing aftermarket springs
aftermarket front springs 0949er 99-04 12 May 1st, 2011 02:29 PM
(Quick Answer Please) Replacing A Hood For Aftermarket greyauto02 V6 Mustangs 22 March 12th, 2009 08:48 PM
Aftermarket tweeters replacing mach 460 midrange Disturbed One General Tech 1 June 30th, 2008 06:17 PM
Aftermarket tweeters replacing mach 460 midrange Disturbed One V6 Mustangs 0 June 30th, 2008 03:56 PM
Aftermarket springs? gregkelley General Tech 4 August 27th, 2007 04:50 PM
