how to fix my misfire
Old July 19th, 2011, 10:10 PM   #1
02edge's Avatar
2000 m112'd 3.8
02edge will become famous soon enough
when my car idles you can hear it miss every once in a while Ive replaced plugs wires coil fuel filter tps iac and a bunch of other things what could be the cause
Old July 19th, 2011, 10:11 PM   #2
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
bad gas is one
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old July 19th, 2011, 10:14 PM   #3
02edge's Avatar
2000 m112'd 3.8
yeah but its always done it and I usually go to hess or shell and always keep it full of premium
Old July 19th, 2011, 10:20 PM   #4
Green_6er's Avatar
2000 Mustang 3.8
u have a tune for premium?
Old July 19th, 2011, 10:21 PM   #5
02edge's Avatar
2000 m112'd 3.8
nope im waiting on my tuner to come in the mail still
Old July 19th, 2011, 10:37 PM   #6
Green_6er's Avatar
2000 Mustang 3.8
that could be your problem. you should only run premium if you have a tune for it because higher octane fuel burns a lil differently
Old July 19th, 2011, 10:38 PM   #7
Green_6er's Avatar
2000 Mustang 3.8
also what kind of plugs did u put in your car?
Old July 19th, 2011, 10:38 PM   #8
02edge's Avatar
2000 m112'd 3.8
autolite
Old July 19th, 2011, 10:41 PM   #9
Green_6er's Avatar
2000 Mustang 3.8
copper or platnium?
Old July 19th, 2011, 10:49 PM   #10
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
im betting copper,
run 87 cause thats what your computer wants, lucky you haven't fucked your engine like that ...
Next id start looking for leaks if the gas doesn't solve it
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old July 19th, 2011, 10:56 PM   #11
Green_6er's Avatar
2000 Mustang 3.8
well i had platniums in mine and it ran like shit so jw
Old July 19th, 2011, 11:31 PM   #12
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
RedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really nice
When was the last time you cleaned your MAF? Have you done a compression check?
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok.
05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel
Old July 19th, 2011, 11:44 PM   #13
2000 gt
Everett will become famous soon enoughEverett will become famous soon enough
Vacuum leak will cause a misfire. And premium won't cause a misfire. Keep using shell gas cause it's a top tier fuel. And premium is more resistant to detonation and preignition. There is no harm using it other than making you lighter in the wallet
Black and White Crew
Crew Member # 3
centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie
Old July 19th, 2011, 11:47 PM   #14
Green_6er's Avatar
2000 Mustang 3.8
yeah +1 for using shell, but you should really only use the fuel that your car is tuned for. and which coil did you put in? I heard from many people that the screamin demon coil packs are poop.
Old July 20th, 2011, 06:46 AM   #15
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
I can't believe people are suggesting you change gas octane to get rid of a missfire BEFORE they suggest you change injectors. You can run premium on a stock tune and it won't hurt a thing besides your wallet.
If you have a partially clogged injector, it can cause a missfire. That's the next thing I would check/change.
Threads Similar to: how to fix my misfire
misfire in cyl 1 AND 6 98Cobra_sleeper 4V / SVT 13 March 12th, 2011 08:01 PM
Misfire still here scxc15 99-04 10 March 25th, 2009 08:20 PM
Possible Misfire? mutabi 99-04 3 December 2nd, 2008 11:22 AM
Misfire on #8 TG02GT 99-04 6 July 19th, 2008 10:52 PM
misfire mpboy 99-04 0 May 25th, 2008 07:46 PM
