I'm Learning Drugs ΔΧ
2000 3.8 Mustang
Car running hot, need quick help!
Okay I'll start by saying i have a 15 minute, at most 5mi commute to and from work. On the way here it was running very hot, i'd say about 3/4-7/8 on the temp gauge, almost in the red when i got here. Two things I'm asking.
1. How the hell can i limp home without getting it to overheat? 2. Whats the underlying problem and how the hell do i fix it?
2001 Mustang
0 - 60 5 minutes
Check coolant levels first before u leave to go home make sure its all good, other than that there rly isnt a whole lot to do other than drive a lil bit till it goes over half then stop cool down then start again. once back id try looking at thermostat to see if its stuck. another thing to check is once ur back ( or before u leave ) start engine let it warm up a bit. u should see 2 hoses on ur radiator. one is an inlet hose one outlet. check to see if both are warm. if one is hot and one cold u more than likely have a clogged rad. keep us posted as to what u find on these few items.
Famous people walk on red carpet because they are rich... I walk on toilet paper because I'm the shit
2000 GT 'vert
Yeah, I would check the top hose.. it should warm up and not be cold. Also, check that your fans come on? Is it a lot of stop and go? If you are moving, do the temps reduce? If you are moving and the temps are not reducing, I would say your flow is clogged.
MM's Official Lucifer
Check for leaks as well. Right where upper rad. hose meets engine, under car, by radiator cap. As said check that upper hose is warm/hot.
Sucks to say I just had to replace the water pump on my '00 for this same issue. Was only ~$75 and the job isn't tough.
Jailbait till 2013
2001 V6 / 94 Z28-gone
0-60 in -10.3
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
like they said, check the coolant level.
2000 3.8 Mustang
Well it limped home barely, it looks like i got a crack in the water pump or the gasket
Jailbait till 2013
0-60 in -10.3
Yuck
2000 3.8 Mustang
Yay for throwing more money away
Jailbait till 2013
0-60 in -10.3
2000 v6 mustang
hmm check coolant level first, then check the radiator for leaks, and check the radiator cap. after you check those then you can go into the water pump because 70% of overheating is caused by faulty gasket or bearings in the pump.
it could also be the fan i forgot that one. _random things that could cause overheating_ incorrect timing lean air/fuel mixture exhaust restriction faulty torque converter incorrect cam timing faulty radiator cap
![]() If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
2000 3.8 Mustang
Well 4 hours later and it was indeed the water pump. Hairline crack running on the passenger side of it. Feels good to actually do something involving the engine.
Jailbait till 2013
0-60 in -10.3
Good job at fixing it
Happy 3000th post
SG
2005 Mustang GT
2001 Mustang V6
I got in here a little late, but I was going to say you can run your heater at full blast to get you home. It will draw away the heat from your motor, but it would have sucked for you
![]() I had an overheating issue not too long ago, but luckily it was just my thermostat. In order to get home I had to turn on my heater, and when it's already 120* out it's no fun at all
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok. 05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel |
2000 3.8 Mustang
Well it just ended up being false hope. Ended up replacing the thermostat and flushing the upper and lower house as well as the radiator and putting new coolant in. Still overheating, I'm thinking something might be wrong with the heater core. Suggestions?
2000 GT 'vert
I doubt it's the heater core, but do the temps reduce if you put heat on full blast?
2000 3.8 Mustang
Very minimally, but the heat is blowing too cool for full heat to be on. Its parked right now i think i might have to take it to a shop im out of ideas
wiggety wiggety whack!
You can run a bypass hose that bypasses the heater core- if the heater core is bad, that would fix it. You also might be able to do that in the parking lot of the parts store, some hose clamps, hose, screwdriver, and some leaked coolant on the ground, and you might be good to go.
Sooo did you replace the water pump?
2000 3.8 Mustang
Water pump was replaced, thermostat was replaced, upper hose, lower hose, and radiator was flushed and new coolant was put in.
Threads Similar to: Car running hot, need quick help!
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 10 | August 28th, 2011 05:58 PM |
| 2002 gt not running??? had multiple missfires not running!! | foxcruzin91lx | 99-04 | 8 | July 20th, 2010 03:00 PM |
| quick quick i need a drinking game for 3 people | BostonPerformance | The Clubhouse | 21 | April 22nd, 2010 12:15 PM |
| Meguiars Quick deatailer.. or Ultimate Quick detailer?? | svtkidd23 | General Car Care & Detailing | 12 | January 26th, 2009 12:23 AM |
| alright quick quick light tint question | thorpedo26 | The Clubhouse | 18 | September 1st, 2008 07:36 PM |
