'03 V6
Clutch issue....damn well better not be
So I was noticing a lot of vibration in my clutch pedal....particularly at low RPMs like when coming to a stop or even just after complete stop. Sometimes I could even look at my clutch pedal and see it moving under the normal engine vibration. Took it in and was told I needed a complete new clutch kit. OK....sh!tty....but ok. Got that work done and the new clutch feels great. Clutch pedal not as nearly hard to depress and much smoother action. Over all....seems like it was the right thing. Now I noticed the vibration in the clutch pedal again and getting worse over the past two days....all this only a week after the work was done. I am noticing a vibration coming from what seems to be a specific area under the hood that seems to be linked with the vibration of the clutch pedal. The strange thing is that when i depress the clutch pedal (basically remove the slack in the pedal travel just to the point of engagement) the vibration and noise disappears. I am not sure if there is just a loose part in the 'linkage' of the clutch pedal assembly or what. I am taking it back to the shop today, but crap....I can't afford another 1000.00+ bill.
BLACK 6er CLUB |
MM's Official Lucifer
They should warranty their work, especially a week later. But it sounds like something is not connected properly, most like the fork / cable connection. Do you know if they examined / resurfaced the flywheel?
1996 V6
It probably just needs to be adjusted. I know how to do it, though I can't seem to do it right on mine & it has the same vibration still. smh.... If I remember right, you pull the clutch pedal all the way up and then slowly depress it. Or maybe it's the other way around? Lol, something along those lines. Maybe somebody else can chime in here....
2000 Mustang 3.8
ehh w/e the mostly stock time is
maybe loose tranny mounts or motor mounts? or something is loose in the linkage.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
2000 Mustang 3.8
2000 Mustang 3.8
to adjust the clutch pedal you just pull up on the clutch pedal and then push it all the way to the floor. it will put the engage the clutch around where the brake pedal is
1996 V6
Holy double posts. Lol. & thanks for the clarification, 6er, I thought that's what it was.
'03 V6
They did resurface the flywheel. I am taking it back in today for a look. Hopefully it is just an adjustment and not something completely different like motor mounts or tranny mounts. I thought it might be something loose in the linkage myself, but what the hell do I know. Thats just what it seemed like to me (first impression especially givent that when I depress the pedal a little bit to take up the slack in the clutch pedal, it all seemed to dissapear)
BLACK 6er CLUB |
1996 Mustang
Sometimes its a bad TOB. I did my clutch and used an aftermarket TOB and it caused my peddle to rattle and it squealed like a stuck pig. Got a ford OEM TOB like everyone says, and I just replaced the clutch fork at same time because I 204K on the car. Now its awesome. Doesnt rattle or squeal and shifts perfect.
My lug nuts require more torque than your Honda makes. |
2000 Mustang 3.8
well the other thing it could be is clutch chatter. and if it is you will probably need a new clutch because if thats what it is, then they didn't install it correctly.
There is a tsb out for the clutch pedal vibration I forget how they say to fix it. But my car has 230xxx and i have drove the last 12xxx miles since I bought it and my pedal has been doin the same I've had no problem at the moment.
#12 | |
SG
2005 Mustang GT
2001 Mustang V6
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok. 05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel |
Dancing Naked In The Rain
What kind of TOB was installed? Aftermarket ones are known to go bad VERY quickly (some have gone out in less than 100 miles). Ford OEM is the only way to go when it comes to TOBs.
Also, $1000+ for a clutch install? That's fucking insane. I paid $250 for my install, $50 for the flywheel to be resurfaced, and $250 for an OEM clutch kit from Ford (had a RAM clutch kit I picked up for $180, but RAM fucked something up and the pressure plate wouldn't line up).
1999 Mustang V6
its the TOB. mine did that shit and its still noisy but the vibration is gone. to fix the vibration i had to replace the clutch cable. the old one had way to much slack in it and with the new clutch was way softer than the old one so the pedal had play. long story short, aftermarket TOB's are ass, and the stock cable overtime will stretch out and allow for excess play in the pedal.
'03 V6
Well after I took it back in, they said the first one just was defective parts (didnt specifiy but probably a bearing issue). They installed a new clutch kit and flywheel and all is good now, and yes, it was covered so no addtional charge.
BLACK 6er CLUB |
Threads Similar to: Clutch issue....damn well better not be
| Damn clutch cable!!!! | cstires | 99-04 | 11 | June 24th, 2011 08:01 PM |
| fuel delivery issue,Damn I'm gettin tired of this | hlinar | 96-98 | 6 | November 9th, 2009 10:00 AM |
| Clutch issue please help | 96whitesvtcobra | 4V / SVT | 19 | July 10th, 2009 04:24 PM |
| i'll never get the damn clutch working right, help pls. | B0B | 99-04 | 18 | June 20th, 2008 01:35 PM |
| clutch issue. HELP | stang02Gt | Modular Mustangs | 0 | February 8th, 2008 12:28 AM |
