Trouble getting spring in
Well up to the point to install the new springs, but having trouble getting them in. Any words of advice?
MM sticker peddler
slowmatic
![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
This is the site I used when I did my springs the first time. Print them off and take out to the garage with u.
99-04 Spring Install Walk Through - Mustang Exhaust Forums |
MM sticker peddler
slowmatic
Where are u getting stuck? Put the spring in position and SLOWLY jack the a arm up. Make sure the spring is seated correctly, then just bolt everything back together.
im at the point were i put the spring in but i cant get the a arm down enough to fit the spring in there?
MM sticker peddler
slowmatic
If the a arm won't lower, u can loosen the bolt on the bushing to relieve some of the tension. Is it getting snagged on something. Post a pic and I'll look at it when I get back from church.
Bigger hammer, bigger pry bar, bigger flame. Works for everything
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome. ![]() |
2001 Mustang V6
make sure to unbolt the sway bar too.
2000 sixxer, 1988 Fox
let the jack down more? what springs are you installing? My h&r ss springs were so much shorter than stock they just slid right in. Id say you could try spring compressors, you can rent them at O'reillys or autozone
It makes my wife horny
16.3@84@5kft
i started with the top of the spring, then used me feet to push the a-arm down and my hands to push the bottom of the spring in. Try putting a prybar in the outer cup edge of the a-arm and bottom of the spring.
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k 1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21 2004 Nissan Armada - HIDs, LEDs, sippy and DVDs 2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
MM sticker peddler
slowmatic
update?
finally got it in, embarrassed on the amount it took
2001 Mustang V6
thats what she said
Threads Similar to: Trouble getting spring in
| Differential S-Spring Trouble | Scholl | V6 Mustangs | 8 | March 1st, 2011 11:00 AM |
| spring Break from spring break and got troubles | ia07gt | The Clubhouse | 0 | March 23rd, 2010 06:57 PM |
| Spring fitting trouble. | britishmartin | 5.0 Mustangs | 2 | February 23rd, 2009 01:23 PM |
| How much trouble (if any..) could I get in | f8youthmidman | The Clubhouse | 10 | May 27th, 2008 08:33 PM |
| car trouble need help! | 5.0tangman | 5.0 Mustangs | 3 | November 30th, 2006 04:33 PM |
