98 3.8 port and polish heads?
Old July 24th, 2011, 12:56 PM   #1
X98stangX's Avatar
1998 mustang v6
slow lol
X98stangX is on a distinguished road
well i watched spike tv this weekend and i saw them port and polish heads i work at a shop i have the tools would it be worth doing to my 98 mustang with the 3.8 stock heads any info would be great
mustang 98 3.8 5 speed 17in akita wheels
98 gmc 1500 4x4 5.7 stock
Old July 24th, 2011, 01:33 PM   #2
dschack's Avatar
2000 sixxer, 1988 Fox
dschack is on a distinguished road
a split port swap would benefit you pretty greatly, food for thought
Old July 24th, 2011, 02:27 PM   #3
Modded V6
Stang6899 is on a distinguished road
Like he said a split port swap is the best bang for the buck but If youre looking for something you can do yourself to add some power you could port and polish your heads, lower, and upper intake manifold.
1999 e46 328i BMW - Daily Driver
2001 SVT Cobra - Project
1995 v6 vert - SOLD
1996 v6 vert - SOLD
1995 v6 vert #2 - SOLD
1995 GT - SOLD
1997 v6 coupe - Parting
Old July 24th, 2011, 02:38 PM   #4
X98stangX's Avatar
1998 mustang v6
slow lol
i am new to the mustangs i was always a chevy guy and i just got this mustang and i love it so i learning as i go abut them lol for the split port swap was all is needed heads intake what else and what are the hp gain
Old July 24th, 2011, 04:58 PM   #5
qwiksilvermustang's Avatar
1999 Mustang Pony
Not even currently moving
qwiksilvermustang will become famous soon enough
40+hp, depending on how much work you do while you have them off... i'd also throw a cam at it while i had it all apart, you'll need the heads lower and upper intake... or you could throw the windstar on there while your at it... swapping to the split ports will give you more options... unless your planning on boosting then i'd just port and pocket those single ports...
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's
Old July 24th, 2011, 08:54 PM   #6
dschack's Avatar
Lmk if you think about doing a split port swap, ive got a pair of heads and both intakes sitting in my closet that you could have for free, all I ask is that you pay for the shipping.
Old July 25th, 2011, 12:21 AM   #7
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
if you did do a splitport swap....and your not going to put a aftermarket cam in then just leave your singleport cam in.
The stock splitport cam is actually worse than the singleport cam
Oh an if you did a splitport swap than you could just port and polish those heads instead
2004 Bolt on & Cammed 3.9L V6
Old July 25th, 2011, 07:46 AM   #8
X98stangX's Avatar
1998 mustang v6
slow lol
what cam should i throw in i pm dschack for the parts i will port and polish them while there off and cams that will really make it go thanks every one
Old July 25th, 2011, 05:02 PM   #9
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
just make sure you know what your doing.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old July 25th, 2011, 06:01 PM   #10
X98stangX's Avatar
1998 mustang v6
slow lol
i am learing but my buddie knows how to do it and he will be right over my shoulder plus for the split port swap what else is need other then heads and intakes as in wires and other stuff you run into
Old July 25th, 2011, 06:39 PM   #11
Modded V6
97+ f-150 V6 heads or 99+ mustang v6 heads
-97+ f-150 v6 lower intake, or 99+ v6 mustang lower intake
-99+ mustang v6 upper intake
-99+ mustang EGR tube and valve (f-150 tube will work, but will need to be modified to clear the inlet for the vortech)
-TPS sensor for TB (1-CX-1488 from Ford) if not already on TB
-99+ TB
-Modified fuel rail that has a universal fuel pressure regulator, and a return line. (available from SteveC)
-Accelerator Bracket (F4SZ-9728-B) if not already included on upper intake
-Throttle cable from 99+ mustang v6
-99+ mustang v6 coil pack and wires
-99+ mustang intake tube, or any 99+ mustang CAI kit
-99+ mustang cooling hoses (including the ones going to the heater core) and pipes. You can also make your own lines, by using plumbing elbows,hoses and clamps, and fab it up yourself. note, if you use the 97+ f-150 lower, you'll have to fab it up yourself
-16 a.w.g automotive electrical wire
-teflon tape, pipe sealant, RTV
-head gaskets (i recommend 99+ mustang gaskets)
-upper and lower intake manifold gaskets.
TB gasket, 94-98 IAC gasket, 94-98 valve cover gaskets(reuse the 94-98 valve covers), exhaust header/manifold gaskets
-you can reuse the 94-98 headers
-use the 94-98 IAC since the 99+ IAC has a different connector
-rad fluid, oil, filter, new spark plugs
-JB weld (if you have a lower intake with the IMRC's since you need to remove them)
1995 v6 vert - SOLD
1996 v6 vert - SOLD
1995 GT - SOLD
Old July 25th, 2011, 08:17 PM   #12
X98stangX's Avatar
1998 mustang v6
slow lol
what are the imrc i am doing this swap not matter what so i am going to need the info lol like a said be for i was a chevy guy forever so this is pretty new and the throtle cable if the intake comes with the mounting will my cable work thanks alot guys
Old July 25th, 2011, 08:32 PM   #13
Dancing Naked In The Rain
mcqueen's Avatar
IMRC = Intake Manifold Runner Control. Just get your lower intake out of a 99-00 Mustang and I can assure you that you won't have to deal with removing the IMRC (they started using them in 01).
My Hubpages
Hey.. r u really a tranny??
Old July 25th, 2011, 08:36 PM   #14
X98stangX's Avatar
1998 mustang v6
slow lol
ok well i am going to take dschack up on his offer as long its not going to be a million dollars to get it to me lol btw dschack what year is all that off of
Old July 25th, 2011, 09:15 PM   #15
dschack's Avatar
You have a pm, need an addy for a shipping quote, and its all off my old 2000 motor w/ about 125k on it
Threads Similar to: 98 3.8 port and polish heads?
How to port and polish your TB, Intake Mani & Heads? 92Notch 5.0 Mustangs 13 August 25th, 2010 02:46 AM
Port & polish LaserRed97GT 96-98 5 April 15th, 2009 05:28 PM
port & polish npi heads joohnn98 96-98 21 February 16th, 2009 02:04 PM
windstar split port swap or port and polish winnie51189 V6 Mustangs 22 November 4th, 2008 04:04 PM
