2002 Mustang V6 vert
need a rear end asap
a weird clunking flapping noise started on thursday and ive figured out that its probably the rear end.i have a 2002 v6 and need to replace the rear end or swap for gt since they both bolt up right? anybody selling one or suggestions of where to look or any help would be great thanks in advance
my rear makes a small clunk sometimes when I put it in gear such as drive. If I hold the brake down fully pressed , I usually dont get the sound,
![]() iTrader: 2 reviews
Where are you located? I have a 7.5" rear out of my 01 that I would sell. I won't ship it tho, so oyu need to pick it up.
#4 | |
Dancing Naked In The Rain
it clunks when coasting.i did jack the car up and when the wheels were spinning the clunking was coming from the rear axle/diff.and im located in northern va near DC
For what it would cost to fix, I would look into getting a used 8.8 rear. Try to stick with a 99-04, earlier years weren't quite as wide. I know the 94-98s are roughly an inch narrower than the 99-04s, so your wheels would both sit 1/2" more into the wheel wells..
yea thats what i was thinking im not looking to fix but replace with either 7.5 or 8.8 and save on labor as well since i could do that myself with some help?
I would go with the 8.8. They'll both probably end up costing nearly the same and the 8.8 is stronger plus it will have a tlok and it usually isn't too hard to find one with upgraded gears. This is something you could do yourself with some help. It should bolt right up and be a pretty straight forward swap.
exactly what i wanted to hear thanks. i cant post in classifieds yet so if anyone is selling one or knows another place to find one let me know
Check your local Craigslist and junk yards. Easiest places to find one since shipping on such a large item would be very expensive.
1996 V6
You know, I always hear this and wonder about putting a 99-04 into an sn-95.. Would it bolt up the same? Would be kind of kool to have the wider stance in the back. Lol
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod. Need cheap parts? CLICK MEEEEEEEEE!! =] |
#12 | |
14.37 @ 96
I have a 7.5 but it needs new spider gears put in it ... blew 6 teeth off it :p
Skar Gone
1998 Mustang V6
17.27@76.66
![]() 1998 5 Speed, CAI, Exhaust, Rear Seat Delete. |
2000 Mustang
slow@slow
Damn, too bad you werent in ks, id sell you my old 7.5 for cheap. And you should have zero problem installing it yourself. Its very easy. And if you can, get an 8.8...Its nice to have a tlok and if your lucky gears!
Run ur car, not ur mouth.
2003 Sonic Blue 4.6L
goodluck finding it on cl, for cheap at least, i rarely find good parts/deals on our CL ill let you know if i come across anything however
Threads Similar to: need a rear end asap
| What rear 4 lug rotor does my fox have need help ASAP | cornellm5 | 5.0 Mustangs | 4 | April 19th, 2011 03:08 PM |
| grr my first rear end??? I need help asap | 02GT89 | 99-04 | 14 | April 18th, 2011 02:55 PM |
| Need help on rear O 2 sensors asap | Exodus | 99-04 | 15 | March 31st, 2009 08:53 PM |
| need help asap | joparrett | 5.0 Mustangs | 11 | March 8th, 2009 11:39 PM |
| need help...ASAP! | VSR13 | V6 Mustangs | 8 | February 5th, 2009 05:35 PM |
