#21 |
Wing on, wing off...
JULY 2011 ROTM
^yours isn't completely in the fender right?
![]() SIG BY WABASHACOBRA99
#22 |
Formerly 01silversixer
2001 V6
15.47@89.57
nope.
It looks alittle different now (cleaned up the wiring and hoses and such) but you get the point.
#23 |
[8MINUS2]
Then I guess I would be like the V6 Titan?
#24 |
6er, you're on the right track with CAI having denser air, and the short ram having less dense air.
The CAI in theory should give you more power for one of 2 reasons. One, being longer tube for the air to flow through. It works kinda like longer runners on an intakae manifold (heard this on a tuner forum, so not 100% sure if its true.) The second reason being the colder/denser air. The more air you put in the combustion chamber, the more fuel you need. The more fuel and air, the more power. The short ram is better for fuel efficiency. Cars are tuned to run with a certain air intake temp. Warmer air is less dense, so therefore it requires less fuel. While some may think its not much better than stock, it does however make the air flow more smooth, so therefore you have less restriction, which helps gas mileage.
![]() 2000 CSVT 03 Escape 3L block, 02 Mercury Cougar 2.5 heads, SVT cams untuned. Stock manifolds, short ram intake, MSDS Y pipe, stock exhaust. 195whp/182wtq 1985 Honda 450 Nighthawk 70+MPG average 8200 miles and counting
Threads Similar to: Air Intake Difference
| Any difference in Cold Air Intake vs... | darienblake | 5.0 Mustangs | 8 | March 14th, 2011 08:36 PM |
| Npi To Pi Intake Difference | Luckybro | 96-98 | 8 | March 23rd, 2010 03:36 PM |
| performance difference between jlt cai and ram air intake | thorpedo26 | 99-04 | 11 | September 27th, 2008 12:58 PM |
| visual difference in the pi and non pi intake | sonicblue | Modular Mustangs | 2 | February 2nd, 2007 03:11 PM |
