Getting Fed UP
Old May 27th, 2006, 04:09 PM   #1
00SoSlow's Avatar
00SoSlow is on a distinguished road
Send a message via AIM to 00SoSlow
Getting Fed UP
Im getting to the point where this exhaust thing is driving me insane... i want it on so bad but i still need the shit to mount it.... i need the tip hangers for a V6, the bracket for the right side, and the 2 rubber cushions. If anyone can help me find some that would be greatly appreciated!!!!!!!!!!!!!!!!
wow i didn't think this would be such a hastle
2000 V6 Performance Red @ Cardomain Was fun but a waste...
1987 LX Hatch | Soon to be a 600hp monster
Old May 27th, 2006, 07:29 PM   #2
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
You could get the passenger side hanger from any GT mustang, salvaged or left unattended in a parking lot. For the tip hangers, consult Magnaflow directly or try emailing Nino about it.
ModdedAutos
1999 Mustang V6
Old May 28th, 2006, 02:36 AM   #3
00SoSlow's Avatar
i got the part number so i think illl just go to my local ford dealer and have them order me some... or just get them if they have them in stock, im sure they do
ill go from there and im making the hangers custom... how long is the vertical part on ur hangers?
Old May 29th, 2006, 10:08 AM   #4
14.79 @ 92.15
Sorry, I have been at the lake this weekend and I have to be at work from 9:45-6 today. I will take better pictures and full measurements of the rear hangers for you today after work.
ModdedAutos
1999 Mustang V6
Old May 30th, 2006, 11:15 AM   #5
14.79 @ 92.15
Here are the measurements from the driver side tip hanger. The passenger side hanger has the same measurements.
ModdedAutos
1999 Mustang V6
Old May 30th, 2006, 05:36 PM   #6
00SoSlow's Avatar
sweet shit man... thanks a ton saved me some dollars, all i have to do is bend my $3 rod i got from ace to the dimensions and i have the hangers
what would i do without the great help from the forums... id be so lost
Old May 31st, 2006, 05:43 AM   #7
14.79 @ 92.15
No problem. Do your tips have the same hanger bolt-on fastener (with the single screw that tightens into the rod)? If so, be sure your rod will pass through the loop on the tip to be tightened into place. You will need to pull the tips hard to the left to get good clearance under the bumper. Pull the driver side tip hard to the left with one hand and tighten down with the other. Also, pull the passenger side tip hard left and tighten to have an even appearance from behind. Artisan00 and I both had an issue where the passenger tip sat up higher to the bumper, and this was a way to fix it. If the GT Cat Back has better fittament, you may not have to worry about it.
Also, the two bends were 90*
ModdedAutos
1999 Mustang V6
Old May 31st, 2006, 01:04 PM   #8
00SoSlow's Avatar
yes mine do have the tighteners on the tops of the tips, and ill keep that in mind when i put them on, hopefully all goes well i orderd the hangers from the local ford store, Ill post more later but i gotta go because im in class on my laptop
