16.Something@Low80s
Air controls not working on any strength but MAX
Just as it sounds, all of my air controls are working only on the MAX setting. LO and the 2 dots between them do absolutely nothing recently. Is it a simple fix? I'm in FL so the AC (Norm ac or max ac) is almost always on max, so it's not a huge deal...just annoying for when I need to try to talk to someone or use a little heat to defrost when it rains. Anyone had this one?
Easy fix. just find the blower motor resistor and replace it.
![]() 2000 CSVT 03 Escape 3L block, 02 Mercury Cougar 2.5 heads, SVT cams untuned. Stock manifolds, short ram intake, MSDS Y pipe, stock exhaust. 195whp/182wtq 1985 Honda 450 Nighthawk 70+MPG average 8200 miles and counting
16.Something@Low80s
Score, thanks for the info. Just hadn't had the problem before and didn't feel like a ton of research.
not a problem. good luck with the repair
2000 Mustang V6 3.8L
Could this problem also relate to my air cutting in and out while I'm driving? It doesn't stop blowing but the cold goes away to what seems like outside air
NOFATCHICKS carwillscrape |
#6 | |
2000 v6 mustang
![]() iTrader: 1 reviews
like 88tempo said. the blower motor works with 4 different resistors my bet is that your 2nd to highest speed resistor went out and now it only works on full because when its on max there are no resistors.
![]() If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
Like 1slowv6 said, its a totally different issue. could be the a/c compressor cutting off from full throttle, or could be the clutch not engaging from wear, or could be low on 134a.
I rarely ever do WOT, even if its like halfway sometimes it does this, I am thinking it is probably wear on the clutch like you said, and is going out while I'm driving, I tested it while i was parked with the engine idling and revved the engine but the clutch didnt disengage but theres no way to check while I'm driving :/.
Is replacing the clutch expensive/hard? also i just filled the freon, sitting at ~45psi running on max
While it could be what 1slowv6 and 88TempoGLS said, I'd bet you have a small vacuum leak somewhere. As you open the throttle from idle you reduce vacuum, and the blend door moves. It's a common issue.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
Threads Similar to: Air controls not working on any strength but MAX
| AC/Heater controls | Dreamer | 2005 - 2010 | 4 | January 24th, 2011 12:45 AM |
| rerouting ac controls | BossOfDaRich | Audio/Video | 1 | March 15th, 2010 10:40 AM |
| ID for ECU and other controls 97 4.6 GT | 97SVTvert | 96-98 | 0 | July 19th, 2008 03:08 AM |
| Blue box behind a/c controls? | gotboost562 | 5.0 Mustangs | 6 | September 2nd, 2007 05:30 AM |
| Heat Controls | NYHigH | 5.0 Mustangs | 2 | December 27th, 2006 09:48 PM |
