I'm doing it wrong
04 Grand Cherokee
List every fluid in the car that could smell sweet burnt
Well I just got out of my car while doing a delivery and I was overwhelmed by a sweet/burning smell. First thing that came to mind was head gasket so I babied the car back to the store and pulled the dipstick, the color looks normal (level was a little low) then I checked coolant color and it looked a little dark but not too dark. What could be that smell and what else should I look at?
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Jailbait till 2013
2001 V6 / 94 Z28-gone
0-60 in -10.3
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
SMELLS LIKE: MAPLE SYRUP
WHEN: After the engine has warmed or possibly even after it's shut off for a few minutes. THE CULPRIT: Coolant containing sweet-smelling (but toxic) ethylene glycol is leaking from somewhere. It could be coming from a radiator or heater hose, a failed intake manifold gasket or cylinder head. It might be coming from a leaky radiator cap or the radiator itself, especially if you smell it outside the car. A strong odor inside the passenger compartment probably means a bad heater core. |
#3 | |
I'm doing it wrong
04 Grand Cherokee
Jailbait till 2013
0-60 in -10.3
maybe coolants just leaking somewhere and it's getting burnt?
since it's sweet you'd think it'd be the coolant.
1996 V6
Sweet equals coolant....Pretty much always. Lol. Check all your coolant pipes. Check all pipes & hoses for cracks or damage. Check all of the clamps to make sure they still have clamping power. Have you touched any part of your cooling system lately?
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod. Need cheap parts? CLICK MEEEEEEEEE!! =] |
14.37 @ 96
someone put sugar in your gas tank :p
Dancing Naked In The Rain
Look around for coolant leaking. My dad used to have a big ol conversion van that was leaking coolant (never did find out where before he sold it) but it definitely smelled like sweet maple syrup when it burned.
And just fyi, there are 2 coolant hoses on the back side of the engine. Found that out when I pulled them off and had a nice mess to clean off the garage floor.
2000 GT 'vert
My guess is you have a crack in the intake manifold.. has it ever been changed out? There's one thing that inevitable with our cars, the cross over pipe on OEM manifold is junk.
#9 | |
I'm doing it wrong
04 Grand Cherokee
And no I haven't touched anything related to my coolant or anything else for that matter. I parked my car for a few hours with a big piece of cardboard under my car, just checked it an hour ago and nothing leaked. ![]() I mean as long as its not going to break anything it doesn't really bother me. I was just asking.
I'm doing it wrong
04 Grand Cherokee
Quick question, what does burning transmission fluid smell like?
#11 | ||
OP, just keep an eye on your coolant, oil, and trans fluid (if it's an auto). More than likely it's an external leak, if you're smelling it strongly outside of the vehicle after driving it. You can check all of your hoses, the water pump, the radiator end tank seals, the heater core drain, etc. to track down the source of the leak.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
2000 GT 'vert
Sorry, didn't realize I was in the V6 section. I guess that's what happens when you use the "new post" button while surfing from work and not paying good enough attention.
#13 | |
MM's king of Neon's
404 - car not found
17.81@87
Look for a spot that has a white/blue residue on it, like treated roadsalt almost. Spots to check would be water outlet, water inlet, radiator in, radiator out, heater in, heater out, and water pump. They use cheap hoseclamps on these cars, and it could be something as simple as that. Since you're getting the smell it's most likely to be on or around the block. Also grab the water pump snout and see if you can wiggle it. If that bearing goes out, it will leak pretty good. Plus that's one of those failures where it can only leak while running.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2000 GT 'vert
You can also clean the engine bay, run to the parts store and pick up radiator dye and use an UV light to spot where the leak is.
01 True Blue v6
to slow to matter
I have never heard of one of our intake manifolds cracking. I know some of the gts have had issues with their plastic manifold cracking but that isn't a problem with our aluminum intakes. OP, are you sure its your car and it wasn't something outside?
I'm doing it wrong
04 Grand Cherokee
Yea I am sure, I've smelt it a few times since. I smell it more when I am standing on the passenger side of my car. Also I can't smell it inside.
I didn't smell it often today though, I did notice (I am going to get yelled at for this) the smell pops up whenever I manually up shift my auto. (sorry it's fun to do every once and a while) Thats why I asked what burning transmission fluid smells like.
#17 | |
MM's king of Neon's
404 - car not found
17.81@87
Keep an eye on your coolant level and color. Does anyone know what kind of trans cooler our automatics use? I know a large number of automatics use a liquid to liquid cooler, which actually exchanges heat in the bottom of the radiator. One of the most common failure modes is the exchanger rupturing and dumping trans fluid into the radiator. You'd notice this in the fluid color though. The only other thing I could think of related to the transmission would be the increased heat rejection from the trans cooler could be causing fluid to be pushed out somewhere. Maybe causing an overflow and it's dumping out somewhere there? I'm grasping at straws here though. These leaks are difficult to track down to say the least. My dad's Ram developed a leak in the radiator hose that would only leak during high speed operation, and due to the airflow under the hood you couldn't pinpoint it. Took quite awhile to figure out.
I'm doing it wrong
04 Grand Cherokee
Coolant color is kind of dark, but its been in there for a while. I am not sure if coolant darkens over time.
EDIT: If I smelt my coolant and transmission fluid was in there would I obviously smell it?
Threads Similar to: List every fluid in the car that could smell sweet burnt
| tranny fluid smell? | Applehead281 | 99-04 | 3 | November 12th, 2009 05:44 PM |
| Burnt Out | qwik48r | 2005 - 2010 | 4 | April 9th, 2008 03:18 PM |
| Ahh, the sweet smell of tax season.. | DanTheMan | The Clubhouse | 30 | March 6th, 2008 06:05 PM |
| Burnt clutch smell? | Regency 2007 | 2005 - 2010 | 5 | July 20th, 2007 09:28 PM |
| Burnt Up | B0mb3r645 | The Clubhouse | 5 | May 18th, 2007 08:29 PM |
