2001 Mustang
![]() iTrader: 3 reviews
lowering/ wheel question
Ok, So im going to lower my 2001 stang like 1.5 inches. I currently only have stock wheels. At some point I want to put 18" rims on it, svt's, fr500's, or something. Im worried that with a 1.5 inch drop and with 18" rims that I will rub, do you guys think ill have any issues??
It makes my wife horny
16.3@84@5kft
no. i did the dibach pro kit with stock wheels and stock size tires. the tops of the wheels were flush with the fender. I put 18s with 245/40s on and now i have about 1 1/2" clearance from tops of tire to fender.
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k 1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21 2004 Nissan Armada - HIDs, LEDs, sippy and DVDs 2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
nope it won't, unless you got the wrong offset and/or wrong tire size
Dark Shadow Gray 1 mod or 2 ![]() Thanks to Sarah for the Sig!! ![]() http://www.moddedmustangs.com/forums...-member-35708/ MM DSG Crew Member#3 |
Wyatt's #1 Slut
N/A
Or hit a pot hole really hard
yeah, cut the stock springs with stock shocks and it will do that every pot hole or so, however If you cut stock springs and run stiffer shocks it won't
Better than ONLYaUNCfan's
2012@lightspeed
Youll be alright, may have to roll the fenders in the back for the tire if you go wider than stock.
Formerly, AhobosCheese and Cheddars.
2001 Mustang
Awesome, thanks for the info guys
MM's Official Lucifer
No need to roll fenders unless you go over 305 in rear, which is completely pointless on a v6.
Check my garage for pics. I have Eibach prokit springs (lowered 1.75" compared to stock measured at the side skirt). Also run 18" Fr5's. At full turn it will rub slightly, but you can buy rack stops for $10 that will eliminate that issue. I also had to customize my driver side fender well by removing the part that sticks out beneath the washer fluid reservoir. Riveted a flat metal plate there and it solved the rubbing issue on that side. See garage for entire mods list.
Either way speedbumps suck... lol
Not Banned
i have the pro kit and 18" saleens, 255 in the front 285 in the rear.
The fronts only rub slightly at full lock my rears only rub when i bottom out on something. |
Priest of the Car Gods
Really is gonna depend on what width you go to and what tires you run on 'em. If you stick to a close-to-stock OD tire and a close-to-stock-width, you'll be fine.
Wing on, wing off...
JULY 2011 ROTM
I have 295s rear and prokit... I had to roll my fenders... Rubbing issue was pretty bad back then.
![]() SIG BY WABASHACOBRA99
Threads Similar to: lowering/ wheel question
| will bigget tires fill up wheel well instead of lowering the car? | 00mustangv6 | V6 Mustangs | 17 | August 12th, 2010 01:59 PM |
| Lowering question | adrenaline=lifeline | 99-04 | 3 | June 18th, 2010 01:36 PM |
| 95' GT lowering question? | Wiseguy | 94-95 | 1 | October 29th, 2008 09:35 AM |
| lowering/wheel combo | beast5319 | 99-04 | 21 | May 1st, 2008 11:55 PM |
| lowering springs and wheel size | motorhead6776 | General Tech | 2 | March 8th, 2008 01:15 AM |
