After a Rebuild I got Codes
Old July 30th, 2011, 10:29 PM   #1
Fixitup944 is on a distinguished road
SUBJECT: 1997 v6 3.8L with caramel/coffee shake mix all through the engine.
FIX: I dis-assembled the engine, flushed and cleaned everything re-gasketed everything, re-placed the water pump while I was at it and carefully re-assembled the engine.
RESULTS: Awesome! Engine starts, runs and purrs like a kitten on steroids.
BUT...I have four codes including a P0135, P0136, P0141 and P1131 (I can't find this one in my manuel).
I think that the 135, 136 and the 141 were caused when I disconnected the sensors upstream and downstream of the Catalytic Convertor...Does that sound reasonable??...and what is the liklihood that those codes will clear after sufficient data has be re-stored in the onboard computer?
Any suggestions?? And does anybody know what the P1131 code is??
Old July 30th, 2011, 10:34 PM   #2
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
rfcsoulja will become famous soon enough
Have you tried disconnecting your battery for a little while to clear the codes?
My supercharged v6
http://www.youtube.com/watch?v=1lNkgKBw0bw
Old July 30th, 2011, 10:37 PM   #3
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
Code: P1131
Info: Lack of Upstream Heated Oxygen Sensor Indicates Lean - Bank No. 1
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old July 30th, 2011, 11:09 PM   #4
Originally Posted by Green_6er View Post
Code: P1131
Yeah...Thanks, I found that in a further search...BUT what does it mean...in plain English?
Old July 30th, 2011, 11:29 PM   #5
Green_6er's Avatar
2000 Mustang 3.8
O2s r bad or not hooked up.
Old July 31st, 2011, 05:43 AM   #6
COuld the computer have lost all of the stored data and therefore triggered an engine code from simply disconnecting those sensors during my re-build?
Old July 31st, 2011, 05:58 AM   #7
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
doesn't mean O2 are bad actually, could be bad, but no one is saying they are ...
You might be actually running lean on that half of the world ...
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old July 31st, 2011, 07:50 AM   #8
I agree with this, especially since I recall replacing one or two of the sensors a while back (within the last two years...real low mileage since then) and when I did the rebuild I also rebuilt the fuel injectors with new o-rings and caps and cleaned em up a bit...
When the code description indicates "Bank 1" what are they referring to? What is Bank 1 vs Bank 2?
Old July 31st, 2011, 09:25 AM   #9
...and hypothetically speaking, IF the upstream O2 sensor was bad at either the electrical connection end of it or the actual sensor part of it could that cause a fault reading at the downstream sensor just because it is in line?
Old July 31st, 2011, 12:47 PM   #10
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Do buy anything else yet. Just clear the codes and see if any come back.
271rwhp N/A V6
Suck it.
Old July 31st, 2011, 12:55 PM   #11
Loki's Avatar
1996 V6
Loki will become famous soon enough
I have the same P1131 code & haven't been able to get rid of it yet. I tried clearing it, no luck. I changed my tune, no luck. Tried cleaning the fuel system, still nothing. The car's running fine, but that code is bothering the hell out of me. Lol, I'll let you know if I figure out for sure what it is on mine.. There's a load of things it can be, tho =/
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod.
Need cheap parts? CLICK MEEEEEEEEE!! =]
Old July 31st, 2011, 09:46 PM   #12
My biggest problem is that it failed the Massachusetts Emission test for its annual inspection because of those codes so now I have a "R"ejected sticker for 60 days until I have to have it repaired and reinspected. So I have 60 days to figure out what I am gonna do.
Threads Similar to: After a Rebuild I got Codes
codes velasco98 5.0 Mustangs 1 February 23rd, 2011 11:00 PM
Buy a built T-5 or rebuild with g force rebuild kit? Cloud Nine 5.0 Mustangs 17 February 21st, 2011 02:25 AM
311 and 314 Codes brando8912 94-95 4 April 30th, 2010 12:40 PM
codes!! 95BlackStang 94-95 16 February 21st, 2009 08:18 PM
Codes krispy V6 Mustangs 8 May 30th, 2008 07:43 AM
