Wheel compatability
Old July 31st, 2011, 10:56 PM   #1
ViperPilot24's Avatar
'03 V6
ViperPilot24 is on a distinguished road
Wheel compatability
Are 17s from an '03 same as 17s from am '05?
BLACK 6er CLUB
Old July 31st, 2011, 11:15 PM   #2
nope....different offsets...they will both fit your car but to look right you'll want spacers on the 05+ wheels
Old August 1st, 2011, 01:21 AM   #3
'03 V6
As I underdtand...spacers can be "questionable"...correct?
BLACK 6er CLUB
Old August 1st, 2011, 01:26 AM   #4
not if you get hubcentrics...i never had an issue running Marks old 1.5" spacers on the back of my GT before i got some wider wheels
Old August 1st, 2011, 01:34 AM   #5
'03 V6
Saw a guy selling 05 17's for 150.00
BLACK 6er CLUB
Old August 1st, 2011, 01:36 AM   #6
i'd buy them then at that price....you can run them w/o spacers but may rub slightly on tight turns on the front until the spacer goes on and the rears will fit no problem..they will just look a bit sunken in until at least a 1" spacer is added
Old August 1st, 2011, 01:40 AM   #7
'03 V6
By sunken you mean like close into the center line of the vehicle....the spacers would go between the whels and the axle? So i'd need 1 or 1.5 inch spacers?
BLACK 6er CLUB
Old August 1st, 2011, 01:42 AM   #8
correct...1" should make it look much better...1.5" should just about flush them with the fenders
Old August 1st, 2011, 01:51 AM   #9
'03 V6
Thanks.bro. Gona price out some spacers while waiting on the seller to get back with me.
BLACK 6er CLUB
Old August 1st, 2011, 03:23 AM   #10
Dancing Naked In The Rain
mcqueen's Avatar
Just to clarify on the rubbing (since I bought my car with S197 Bullitts on it and they're back on it now), the front wheels will only rub when you have them completely turned and even then it's pretty minor.
My Hubpages
Hey.. r u really a tranny??
Old August 1st, 2011, 12:18 PM   #11
'03 V6
Thanks for the info. I am waiting to hear back from the guy about the wheels. Im shopping for spacers right now. Wondering if it is going to be cost effective to buy these wheels and spacers or just keep shopping around for the right wheels for my car that won't require spacers.
BLACK 6er CLUB
Old August 1st, 2011, 12:28 PM   #12
Wing on, wing off...
MRKsD3's Avatar
JULY 2011 ROTM
MRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of light
I love wheel spacers! I had them before....but sadly they add more weight on the wheels... A good 3-3.5 lbs... With our cars having so little power, you wouldn't want the extra weight... (may not be a biggie for you )
I suggest you just keep searching for NE wheels...
SIG BY WABASHACOBRA99
Old August 1st, 2011, 12:40 PM   #13
'03 V6
Well if it was a weight issue, I could always take the spare out of the trunk, lol
BLACK 6er CLUB
Old August 1st, 2011, 12:56 PM   #14
MRKsD3's Avatar
JULY 2011 ROTM
LOL believe it or not, I've tried that too! Didn't help...
It's up to you bro... was just saying...
Old August 1st, 2011, 01:09 PM   #15
mcqueen's Avatar
Just a heads up, weight in the rear isn't always a bad thing. Depending on what you do to your car, you might need some weight to keep your tires from spinning when you launch.
My Hubpages
Old August 1st, 2011, 01:14 PM   #16
Mana_MGT's Avatar
2003 Mustang GT
15.8@ 100-ish Mph
Mana_MGT will become famous soon enough
Get some fatter rears!!! Traction issue solved!!!
how do they look anyway? Like i mean is it worth it? will you paint them?
Dark Shadow Gray
1 mod or 2
Thanks to Sarah for the Sig!!
http://www.moddedmustangs.com/forums...-member-35708/
MM DSG Crew Member#3
Old August 1st, 2011, 03:00 PM   #17
'03 V6
Im really just wanting a style change. You can see the stock wheels I have in the avatar pic, but the ones I was looking at are a Bullitt Style.
BLACK 6er CLUB
Old August 1st, 2011, 04:34 PM   #18
qwiksilvermustang's Avatar
1999 Mustang Pony
Not even currently moving
qwiksilvermustang will become famous soon enough
Sprung weight(ie... spare tire, heavy seats) is alot different than rotational weight(ie. wheels, driveshaft,flywheel etc..) Which is why you want lighterflywheel, clutch assembly, driveshaft, lightened gears, wheels..
sprung weight does not effect power output like rotational weight does. I've ran them on other cars, its not that big of an impact but you can tell on the butt dyno..lol..
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's
Old August 2nd, 2011, 12:54 AM   #19
'03 V6
I am rwally not worried about weight. Ri ght now I am not trying to out run anyone. I want a cool loking ride that rins nice. If I want sheer power ill get a gt or some thing.
BLACK 6er CLUB
Threads Similar to: Wheel compatability
4.6 compatability question HamToast 99-04 4 March 26th, 2011 11:54 PM
PCM Compatability sjr56 99-04 4 September 2nd, 2008 09:54 AM
5.4 to 4.6 compatability? 97S281 Modular Mustangs 7 August 21st, 2008 03:59 PM
compatability AnFking6908 V6 Mustangs 4 June 9th, 2008 01:42 AM
Compatability of a v6 and a T5 TwinFox V6 Mustangs 4 July 5th, 2006 09:34 AM
