#1 | ||
'00 Mustang V6
0-60 Sometimes
Need help asap!!!
As some of you may know I was having misfire issues after using seafoam yesterday. Coded a misfire in cylinder one. Changed the spark plug in cylinder one and started it up and seamed to run fine. This morning there was a slight misfire on acceleration so I changed all the plugs. Now the misfire us worse than it was yesterday. I seriously need some help!
![]() O/R Hpipe, Jegs GT catback, Cobra Rs, CAI, Visuals
1999 Mustang V6
did you do wires too?
#3 | ||
'00 Mustang V6
0-60 Sometimes
A few weeks back
03 Mach 1
oh shit... i was going to seafoam
You may have dislodged enough carbon to foul up the plugs.
I would try driving it some distance to clean the carbon out, then remove the plugs and remove any carbon from them. After that hopefully it will be OK. Replacing the wires might also be a good idea. |
Dancing Naked In The Rain
100% sure the #5 and 6 wires are on the correct plugs?
2000 Mustang 3.8
ehh w/e the mostly stock time is
yeah what mcqueen said because cylinders 5 and 6 are tricky lil bastards and r switched up. also could it be your coild pack possibly just decided to go out coincidentally?
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
#8 | ||
'00 Mustang V6
0-60 Sometimes
Ok just checked and I did switch 5 and 6. that fixed the really bad misfire but still have the same misfire like yesterday. Is there any way to check the coil pack before buying a new one?
Gotta start with the dumb little shit man, most problems are less complex than one would think
And I think you can test the coil pack with a voltmeter.
It makes my wife horny
16.3@84@5kft
you can just do the old screwdriver trick, or ohm out the wires and see if one or more are bad. are you getting a cel?
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k 1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21 2004 Nissan Armada - HIDs, LEDs, sippy and DVDs 2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
#11 | ||
'00 Mustang V6
0-60 Sometimes
yeah the only codes are misfire in cylinder one and fault in o2 sensor which is just from my exhaust change
16.3@84@5kft
verify the following, spark on the plug, fuel pressure (specifically fuel to cylinder one), and what fault are you getting for the o2 sensor? there is more than one fault detectable for each sensor.
#13 | ||
'00 Mustang V6
0-60 Sometimes
Took her to the shop today and they found that one of the wires had ended up resting on the magnified and burned through the insulation which caused an arc across the manifold. It burned out 1 and 6 of the coil pack. Completely coincidental that it happened right after seafoaming it. Just glad that its getting fixed right.
#15 | ||
'00 Mustang V6
0-60 Sometimes
It was $363.90. That included new wires, new coil, oil change, and labor. They also somehow got rid of my O2 sensor error code
They might have just cleared the code. You'll know in a couple of days.
#17 | ||
'00 Mustang V6
0-60 Sometimes
It usually turns back on within 10mins of driving, didn't this time, I guess we'll see though
Threads Similar to: Need help asap!!!
| Need help ASAP! | 03_StangGuy | 99-04 | 15 | December 13th, 2009 06:19 PM |
| need a new fox asap | oscrfsh | 5.0 Mustangs | 14 | November 29th, 2009 11:55 AM |
| need help asap | oscrfsh | 5.0 Mustangs | 12 | September 4th, 2009 12:47 AM |
| need help asap | 91cobra5.0 | 5.0 Mustangs | 8 | April 16th, 2008 07:20 PM |
| Help Asap | MikeD05GT | 96-98 | 10 | December 27th, 2007 07:47 PM |
