so i just picked this up. I want to use it on my Stock V6 3.8L mustang
Old August 2nd, 2011, 01:11 AM   #1
1998 Mustang
jrp11888 is on a distinguished road
Thumbs down
Im not doing anything tremendous. Just wanna build it for fun. What all is involved besides this stuff. Whats the least amount of stuff i need.
i cant find the old thread on SC swap i had saved on my laptop, but i want to do this easiest as possible. I had all the info to do it before and was ready to roll but had to put it on a hold because of parts. i picked these up yesterday for a KILLER DEAL!
Let me know, Thanks
-Mods-
rebuilt 7.5 rear, posi, 3.73's, 245/55/16 sumi racers, CAI
-Future-
4.2L swap, ported lower, windstar upper, UDP, Tune, dual exhaust, short shift kit...etc
Old August 2nd, 2011, 01:58 AM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Let me know, Thanks
Alright so here you go this is what you still need:
-SC thermostat housing
-SC jackshaft pulley bracket
-SC PS pump bracket
-SC crank pulley
-SC water pump and pulley
-PS pump pulley (you can us your mustang pump)
-SC tensioner pulleys (all 3)
-if using the SC block/crank then use the 94-95 neutral balanced dampener with exeter gear, some dampeners off the F150 will work as well.
-if using the mustang block/crank then use you stock mustang dampener
-if using the SC block/crank then use the SC flywheel/flexplate
-if using the mustang block/crank then use the mustang flywheel/flexplate
-Mustang or SC starter will be fine, they are the same
-Mustang headers
-SC heads are better but Mustang heads would probably be fine (SC heads are supposedly a little stronger)
-SC injectors or eqivilent plus matching MAF
-89-93 SC came with 30# injectors and 55mm MAF
-94-95 came with 36# injectors and 70mm MAF
-all cooling hoses
-SC thorttle cable
-SC throttle cable bracket
-MUSTANG EEC
-MUSTANG wiring harness
-wire to lengthen wiring harness connectors
-extra cooling hoses for custom work
-MUSTANG timing chain cover or 94-95 SC timing chain cover
-MUSTANG crank sensor
-MUSTANG or SC alt will work, MUSATNG better sicne it has the extra connect on it, but will work without it for the SC alt, need to change pulleys if using the Mustang Alt. I believe the Mustang alt is more powerful as well, not exactly sure.
-SC AC compressor
-custom AC lines
-custom air inlet needed
-SC intercooler should work, not sure how well the SC intercooler tubes will clear but they should
or use a custom IC setup like me [img]images/smiles/icon_smile.gif[/img]
-Mustang motor mounts
-SC valve covers
-Mustang DIS module, don't need the SC one.
-SC oil cooler (not needed but good to have)
-Mustng rad will work, but if using the SC IC then might be easier to us ethe SC rad its a little smaller though but works for the SC guys fine.
-Major tuning
-SC coil pack bracket (mustang coil pack should work but I have the SC coil pack as well)
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old August 2nd, 2011, 03:24 AM   #3
Wing on, wing off...
MRKsD3's Avatar
JULY 2011 ROTM
MRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of light
-SC PS pump bracket
-SC crank pulley
-Mustang headers
-all cooling hoses
-SC thorttle cable
-MUSTANG EEC
-SC AC compressor
-custom AC lines
-SC valve covers
-Major tuning
PHSSSSHHHHHH!
THAT'S IT?!
SIG BY WABASHACOBRA99
Old August 2nd, 2011, 07:34 PM   #4
1998 Mustang
-SC PS pump bracket
-SC crank pulley
-Mustang headers
-all cooling hoses
-SC thorttle cable
-MUSTANG EEC
-SC AC compressor
-custom AC lines
-SC valve covers
-Major tuning
-SC PS pump bracket
-SC crank pulley
-SC valve covers
If i have the complete 3.8L already installed in my car in good working order...why do i need to use all these accessories from the SC engine? just wondering what the necessity of these components is. Thanks
-Mods-
-Future-
Old August 2nd, 2011, 09:54 PM   #5
1998 Mustang
-SC PS pump bracket
-SC crank pulley
-SC valve covers
just wanted to know why i need to change these things? ie. fitment, hookup? idk thats why im asking. lol
-Mods-
-Future-
Old August 3rd, 2011, 03:56 AM   #6
bonzi4688's Avatar
00"V6/410/SCT/BBK Intake
bonzi4688 is on a distinguished road
Send a message via AIM to bonzi4688
Nice kit!
00" 6'R BBK CAI/ 7.5 28 spline 4.10'd /SCT-X3 Tuned
Old August 3rd, 2011, 04:03 AM   #7
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
-SC PS pump bracket
-SC crank pulley
-SC valve covers
because the s/c is setup differently than a 3.8 mustang
3-belts
Old August 3rd, 2011, 10:54 AM   #8
2007 V6 Mustang
kentuckyyeti is on a distinguished road
Guess I won't be doing a supercharger add-on for mine. I had no idea what was involved. My hat's off to your guys that have done the conversion.
Old August 3rd, 2011, 11:21 AM   #9
Loki's Avatar
1996 V6
Loki will become famous soon enough
kentucky, yours would probably be a bit easier since you have an '07. These guys are talking about an m-90 swap on an sn95.. The easiest way to do it is to get the whole engine, btw. lol, an m-90 swap gathering parts piece by piece has got to be both time consuming, and expensive after a while!
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod.
Need cheap parts? CLICK MEEEEEEEEE!! =]
Old August 3rd, 2011, 11:34 AM   #10
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
OP, I should have at least some of the parts you still need here at my shop. Just send me a PM with your zip code for shipped prices, if you're interested.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old August 3rd, 2011, 08:47 PM   #11
1998 Mustang
ill probably need injectors and a fuel pump too. can anyone link me to an upgraded fuel pump that will work with my setup?
-Mods-
-Future-
Old August 4th, 2011, 04:04 PM   #12
Tang Stang's Avatar
I'll check on those parts for you tonight. As far as the fuel pump is concerned, a standard Walbro 255 LPH should be more than enough.
Old August 5th, 2011, 10:24 PM   #13
1998 Mustang
can anyone link me to a compatible upgraded fuel pump per websites or something, would be greatly appreciated. Thanks
James
-Mods-
-Future-
Old August 5th, 2011, 10:26 PM   #14
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
y did he give you 2 superchargers?
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old August 6th, 2011, 05:17 PM   #15
1998 Mustang
he had 2, he decided not to do the swap so sold me everything in the pic as a bundle.
-Mods-
-Future-
Old August 6th, 2011, 07:15 PM   #16
Green_6er's Avatar
2000 Mustang 3.8
ahh alright, good back up if yours ever goes bad. or you could try porting one of them.
Old August 8th, 2011, 09:11 AM   #17
Tang Stang's Avatar
James
Either of these would be enough, though I'm sure you could find a better price on them if you shop around.
Super Coupe Performance Parts - Ford Thunderbird, Mercury Cougar, Lincoln Mark VIII (8) and Ford Escape
Threads Similar to: so i just picked this up. I want to use it on my Stock V6 3.8L mustang
Picked up 2012 Mustang CS Help me with mods! zim-300srt8 2011+ 36 June 1st, 2011 12:18 PM
Just picked up my first Mustang GT. the_fish New Members Introductions 9 April 4th, 2011 02:31 AM
Just picked up a black 1995 Mustang 5.0 for 650.00 06Black5spdGT 94-95 23 June 9th, 2009 10:23 AM
just picked up my first mustang, video and pics inside :) steve da p0pe 5.0 Mustangs 25 September 1st, 2007 07:03 AM
Just picked up my '84 Mustang L! Mazlem 5.0 Mustangs 5 December 18th, 2006 07:55 PM
