Thermostat
Old August 5th, 2011, 01:44 PM   #1
laser98 is on a distinguished road
Thermostat
Hi all. I am fairly new here and just bought a 96 v6. Needless to say, the previous owners have done some stupid things to this car. The car is running hot so I am doing the basic maintenance things to the cooling system. The question I have is this: does the spring on the thermostat face the radiator or the engine? I believe it is the engine but I am uncertain. When I took the old thermostat out it was facing the radiator so I wanted to check since I don't trust what has been done to the car in the past. Thanks for any help.
Old August 5th, 2011, 01:50 PM   #2
I'm Learning Drugs ΔΧ
carney's Avatar
2000 3.8 Mustang
carney is a glorious beacon of lightcarney is a glorious beacon of lightcarney is a glorious beacon of lightcarney is a glorious beacon of lightcarney is a glorious beacon of lightcarney is a glorious beacon of light
The spring should be facing in towards the block
No, but mine has a giant rubber cock on it
Old August 5th, 2011, 01:51 PM   #3
Damnit. That's what I thought. Thanks man.
Old August 5th, 2011, 01:55 PM   #4
carney's Avatar
2000 3.8 Mustang
No problem. I just got over a little overheating debacle myself, ive learned the system pretty good
Old August 5th, 2011, 08:24 PM   #5
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
RedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really nice
How did they even install it with the spring facing towards the radiator? Also when you refill your coolant, make sure you get rid of all air bubbles in your lines. An Air bubble can get stuck around the thermostat and cause it to overheat.
Carney, what was the verdict on your overheating issues?
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok.
05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel
Old August 5th, 2011, 10:04 PM   #6
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
he had a cracked water pump
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old August 5th, 2011, 10:28 PM   #7
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
I thought he replaced that and it was still overheating though?
Old August 5th, 2011, 10:32 PM   #8
Green_6er's Avatar
2000 Mustang 3.8
idk last i saw he said he had a crack in his water pump.
Old August 6th, 2011, 12:24 AM   #9
carney's Avatar
2000 3.8 Mustang
Cracked waterpump, faulty gasket when i replaced the pump, then air got into the system and i was running way way way low on coolant. All fixed and running good.
To OP, make sure your radiator is full of coolant before you run it. And to bleed the air out of the system, pop the cap on the coolant tank and open up the bleeder screw. Its the screw on the black metal line right above the water pump.
Old August 6th, 2011, 12:39 AM   #10
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
Glad you got it fixed dude.
And to piggy back on your post, Also make sure you squeeze your upper radiator hose to help push out the air bubbles.
Old August 9th, 2011, 10:26 AM   #11
Yeah I got the air bled from the system and everything seems to be working fine although it still runs hotter than I would like but when it's 108 outside I guess that's to be expected. When I bought the car there was paperwork showing where the previous owner had the water pump and hoses replaced. My guess is, that the dumbasses that replaced those components also replaced the thermostat and didn't pay attention to what they were doing.
Threads Similar to: Thermostat
Thermostat ajr1230 5.0 Mustangs 35 April 25th, 2010 11:21 PM
180 thermostat Bush18 99-04 3 July 1st, 2009 06:58 PM
Thermostat 5.oh.ROOK 5.0 Mustangs 5 June 26th, 2009 10:17 AM
thermostat 93lx306dev 5.0 Mustangs 11 May 20th, 2008 12:42 AM
180* thermostat jbm5781 96-98 2 August 12th, 2007 10:42 PM
