I Cannot chase down this problem! plz advise!
LinkBack (1) Thread Tools
Old August 6th, 2011, 03:55 PM   1 links from elsewhere to this Post. Click to view. #1
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
Jobra98 is on a distinguished road
Post
Hello to all Members!
My Name is Joe, My pony's name is Jobra, he a 98 3,8l V6, true strait duels to flow-masters NO cat, MIL eliminators, Stock Engine and Tranny, adding deferential soon for positive track! He have a cold here are the symptoms;
1. Take of acceleration boggs down till about 3k RPM then it WAKES up and takes off...
2. Pulsating idle very hard with A/C on
What ive done so far to correct this (info from moddedmustangs.com!!!);
1. New fuel filter
2. new plugs and wires
3 new coil pack OEM
3 new egr valve
4 cleaned MAF
5 Cleaned throttle thing on top of intake (sry little mind boggled)
6 SEA-FOAM tank, crankcase, and vac lines.
Here is a video of what its doing!!
The problem Fix is to Disconnect battery to reset ECU, then Jobra runs strong and is a completely different transformer!
BUT what else can i do to fix problem MYSELF? (also got a date with auto shop Monday to hook it up to CPU)
PLEASE ADVISE MODDMUSTANGS MEMBERS!
<iframe width="425" height="349" src="http://www.youtube.com/embed/3p0otqQJ_vM?hl=en&fs=1" frameborder="0" allowfullscreen></iframe>
joeshopkins@hotmail.com
Old August 6th, 2011, 04:01 PM   #2
Dancing Naked In The Rain
mcqueen's Avatar
Are you talking about the IAC? I'm not totally familiar with SN95 upper intakes, but that's the only thing I can imagine you're talking about. If so, I would try cleaning the throttle body and checking for vacuum leaks (especially around gaskets, those get brittle after 13 years). I would put my money on a vacuum leak.
My Hubpages
Hey.. r u really a tranny??
Old August 6th, 2011, 04:09 PM   #3
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
Yes IAC thank you, Cleaned throttal body with cleaner without squirting it IN the body (finger cleaned it) the vacs comming from EGR valve area dont leak when i blow through them.
If it could be a vac leak why do you think i can reset ECU and it work great for a day or so?
Old August 6th, 2011, 04:53 PM   #4
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
RE- checking vacs.. anything else?
Old August 6th, 2011, 05:08 PM   #5
Loki's Avatar
1996 V6
Loki will become famous soon enough
Stupid question, but have you checked your air filter? Lol
Sounds like you're having an air or fuel problem somewhere.. Or maybe one of your fuel injectors is bad/clogged?
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod.
Need cheap parts? CLICK MEEEEEEEEE!! =]
Old August 6th, 2011, 05:49 PM   #6
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
...air filter is ok. im about to point the finger there (injectors). I thought it was a fuel/air ratio problem too?! but again why would it go back to running great after battery disconnect? Ive checked almost all things to test?! lol I guess i need to learn about Fuel Injectors LOL
Any one Else?!
Thanks guys so far so good!
Not All Who Wander Are Lost.
Old August 6th, 2011, 06:29 PM   #7
Modded V6
Stang6899 is on a distinguished road
CEL (check engine light) on?
1999 e46 328i BMW - Daily Driver
2001 SVT Cobra - Project
1995 v6 vert - SOLD
1996 v6 vert - SOLD
1995 v6 vert #2 - SOLD
1995 GT - SOLD
1997 v6 coupe - Parting
Old August 6th, 2011, 06:36 PM   #8
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
No Sir!
Had on because of back o2s. added mil eliminator (no cat) and bunny tailed o2s to trannie. No Light No Cat No O2s
Weird ain't it LoL
Old August 6th, 2011, 06:40 PM   #9
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
My car sounded like that when the timing was way off. Drove like a slug until you were high up in the RPMs
That is on my old 88 5.0 though. Not sure how you new and improved guys do that w/o a distributor
Old August 6th, 2011, 06:47 PM   #10
Holy Dick Castle!
dr.gonzo!'s Avatar
Crankshaft position sensor
Old August 6th, 2011, 07:01 PM   #11
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
second person who said that! CPS, the other guy said it it was that it would throw a code. --per orilys. My pipe sound like 302 pur. but getting back to the point if it was the timing wouldnt it throw codes and how can it magicly be back on tims? hmmm did you watch video?
Q: can timing bog down engine when in R or D and heavier with A/C on?
*thanks, Joe
Old August 6th, 2011, 07:01 PM   #12
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
*thanks, Joe
Old August 6th, 2011, 07:02 PM   #13
MM sticker peddler
Shelbydog!'s Avatar
slowmatic
Shelbydog! is just really niceShelbydog! is just really niceShelbydog! is just really niceShelbydog! is just really niceShelbydog! is just really nice
So, correct me if I'm wrong, but the idle hops when the ac is on, and it drives like crap with the ac on? I'd say its the ac. Maybe the clutches in the ac unit are grabbing or worn out? Try running a short belt to bypass the ac, and see if it runs any better. That would isolate the prob to the ac. That's the only thing i can think of.
Old August 6th, 2011, 07:07 PM   #14
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
another guy said that too but then he said that i f it was that then disconnecting battery and letting ECU reset would not make it work again.
It does this not all the time, the A/C load was just to heavy down engine so you could hear how it sounded. but i WILL try that!
Thanks, Joe
Old August 6th, 2011, 07:18 PM   #15
Loki's Avatar
1996 V6
*thanks, Joe
That actually makes more sense seeing as how it runs fine for a bit after a battery disconnect.... & I'll tell you from experience that a bad CPS will not always throw a code. It didn't for me
Old August 6th, 2011, 07:19 PM   #16
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
Another video, i thought it was going to do fine but as you see...!!?!?!?
Old August 6th, 2011, 07:24 PM   #17
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
Ok thanks again man!!!
Old August 6th, 2011, 07:52 PM   #18
MM sticker peddler
Shelbydog!'s Avatar
slowmatic
Man, I hate taking things to a mechanic but that may be your best bet. Definitely keep us updated.
Old August 6th, 2011, 09:18 PM   #19
95 5.0L COBRA
Jobra98's Avatar
95 COBRA
ill let everybody know what the shop says monday or tuesday!!
keep pointing out something i might have missed please!!!
ALL INFO HELPS!!
Old August 6th, 2011, 11:36 PM   #20
spaseghost's Avatar
It makes my wife horny
16.3@84@5kft
spaseghost is on a distinguished road
the easiest way to check for a vaccum leak is to spray some brake-kleen around the engine and intake area, and see if the idles changes. if it does you have found the leak. but given it changes with ecu reset, i would say just take to a dealer and have them diagnose it. hell, i didnt put my wire on the plug for cylinder 3 all the way and i never got a cel, but it ran like dick till i put it back on. if the sensors are still sensing properly, you wont gt a cel.
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k
1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21
2004 Nissan Armada - HIDs, LEDs, sippy and DVDs
2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/228760-i-cannot-chase-down-problem-plz-advise.html
&#8234;Jobra98's Channel&#8236;&#8207; - YouTube This thread Refback August 6th, 2011 04:05 PM
Threads Similar to: I Cannot chase down this problem! plz advise!
Injector advise / problem car! Matcheskat 96-98 14 July 22nd, 2010 12:58 AM
Dallas Car Chase white03v6 The Clubhouse 6 June 29th, 2009 04:25 PM
best car chase eva! stangfreak The Clubhouse 11 December 24th, 2008 03:28 PM
the chase mpboy 99-04 3 May 27th, 2008 06:47 PM
Best Car Chase? jessy_is_rad The Clubhouse 17 October 27th, 2006 07:16 PM
