4R70W Automatic Transmission Issue?
Old August 7th, 2011, 01:04 PM   #1
6stang's Avatar
1997 Pacific Green 3.8
6stang will become famous soon enough
Exclamation
I am still trying to get my ('97 V6 running right, but now I have a new problem with the tranny.
When I put the car in R to back out of my spot it clicks right into gear with no problem. However when I put the selector lever into D/2/1 it wont go into forward unless I rev the engine up to almost 4000rpms sometimes. and is now starting to jump out of gear even under power....
I am nervous that this (seemingly minor electrical) issue will worsen/become mechanical if I drive it too much more with this probblem.
Any technical info and/or advice would be greatly appreciated
-Nathan (formerly known as Stang3.8)
Old August 7th, 2011, 03:45 PM   #2
mangogirl205's Avatar
2001 V6 Mustang Vert.
mangogirl205 is an unknown quantity at this point
Hey 6stang,
I don't know alot about this issue but maybe another person will chime in.There are alot of guys/gals on here who know alot. I hope what ever it is you get it resolved soon.
Old August 7th, 2011, 03:45 PM   #3
Hey 6stang,
Old August 7th, 2011, 03:58 PM   #4
Lumoon's Avatar
2001 Mustang V6
Its a V6
Lumoon is an unknown quantity at this point
Service record on the transmission?
If your one of the never been serviced crowd I fear this will get expensive quick.
it could be one of several things.
Filter clogged
valve body springs wearing out
clogged valve body
bad clutch packs o the forward gears
this may help you it is the best resource for the 4R70W I've found TCCoA Tech Articles
Done so far:
3.73 w/ lsd rear end.
custom 91 octane tune by R Style Performance
rebuilt 4r70w
24% UDP pulleys
aluminum drive shaft
Windstar ready to be installed pending ported lower intake arrival
Old August 7th, 2011, 07:00 PM   #5
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
take that SOB to a tranny shop and talk to them. While your at it. Start looking for a new tranny on CL or something. V6 auto's are easy to find usually
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old August 7th, 2011, 07:12 PM   #6
Redfiremustang's Avatar
2003 V6 pony package
Redfiremustang is on a distinguished road
sounds like an torque converter.
2003 Pony Package 3.8L
Mello-Tone XPS Exhaust - true duals 2.5" after cats to 3" tips
Stock 17 inch chrome wheels.
CAI,Tuned,tinted 35%
Old August 7th, 2011, 08:06 PM   #7
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
sounds like your clutch packs are going bad.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old August 7th, 2011, 09:55 PM   #8
6stang's Avatar
I just had the tranny rebuilt by a friend as a favor. my used jmodded vale body and new b&m trick shift auto trans fluid. Onstalled by myself with a remanufactured torque converter. Under 5k miles on the rebuild though. :/
Old August 7th, 2011, 10:02 PM   #9
Loki's Avatar
1996 V6
Loki will become famous soon enough
With automatics, you have to take it to a shop. They'll plug it into their scanner and it'll show what's working. Did this in class before, you'd be surprised at the info those things give you! Lol, but I'm not sure exactly what your problem would be. I would take it to a shop first. If they can't figure it out thru a scanner, they'll have to pull it apart to check it out & pressure test to make sure clutches are engaging properly, etc..
I HATED working on automatic transmissions -____-
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod.
Need cheap parts? CLICK MEEEEEEEEE!! =]
Old August 12th, 2011, 07:45 PM   #10
6stang's Avatar
1st gear replaced, she goes like a raped ape now! thanks for the help guys.
Threads Similar to: 4R70W Automatic Transmission Issue?
performance automatic waranty issue? blk.snake 5.0 Mustangs 0 July 23rd, 2011 12:14 PM
4r70w automatic swap parts pics!!!!! tbirdscwd 99-04 54 October 9th, 2010 10:54 PM
automatic tranny/4r70w roast&toastEM 94-95 19 May 2nd, 2010 02:59 PM
4R70w transmission sketchball77 96-98 10 April 27th, 2008 09:01 PM
3-Speed Automatic Tranny Issue BoomerSixZero Classic Mustangs 25 February 23rd, 2007 03:07 PM
