tackling the fuel side of the FI demon
Old August 7th, 2011, 04:07 PM   #1
Lumoon's Avatar
2001 Mustang V6
Its a V6
Lumoon is an unknown quantity at this point
So I'm in the process of gathering all the small odds and ends for the build.
So far I have
39# injectors
90mm lmaf
aluminum drive shaft
3.73 gears (w/ T-lok)
all the piping and mounting brackets for the S/C + intercooler (dual core)
abs relocation kit (still not sure if I have abs, the car has the abs sensors but the wheels lock up like a mofo)
UDP for the A/C
windstar intake to slap on in the near future
and misc hardware
I still need a head unit for the S/C the one i found with the piping and everything turned out to be empty... >.< and a new SVT fuel pump.
So that brings me to this. Where can I get a quality SVT or equivalent pump for a reasonable price. and is one pump sufficient or do I need to go to a dual pump setup i see alot of people running? What this non-sense of return style fuel systems I keep hearing about... when it comes to fuel I'm like a child looking on with glassy eyes at an adult speaking french. I know the basics. Pump sends fuel to a pressure regulator which sends it to the rails which feed the injectors and so on a so forth modern magic.
please help.
Done so far:
3.73 w/ lsd rear end.
custom 91 octane tune by R Style Performance
rebuilt 4r70w
24% UDP pulleys
Windstar ready to be installed pending ported lower intake arrival
Old August 8th, 2011, 01:34 PM   #2
2000stallion's Avatar
2000 Mustang
slow@slow
2000stallion will become famous soon enough2000stallion will become famous soon enough
The only fuel stuff you really need to worry about is injectors and a pump. And i knew a really place to pick up the pump at a really good price...Ill look around for it...Mp4 gave me the link when i bought a new SVT pump
For Sale:
99-04 smoked tail light covers
Old August 8th, 2011, 01:34 PM   #3
2000 Mustang
slow@slow
oh yeah, and one pump will be fine
For Sale:
Old August 8th, 2011, 09:17 PM   #4
Lumoon's Avatar
2001 Mustang V6
Its a V6
Alright. And the stock lines and rails are good enough to support the larger pump?
Will an SVT pump support the 39#ers i have?
Done so far:
rebuilt 4r70w
24% UDP pulleys
Old August 8th, 2011, 11:25 PM   #5
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
The stock lines will be fine.
The pump should max out at about the same time as the injectors although they seem to vary quite a bit.
Go find the cheapest place you can to buy Motorcraft PFS-204. Good quality SVT pump.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Threads Similar to: tackling the fuel side of the FI demon
Tackling 101 TheUNZippee! The Clubhouse 13 November 6th, 2009 11:37 AM
DEMON Carb leakin fuel HELP MStang79 5.0 Mustangs 12 December 16th, 2008 10:33 PM
Drive side fuel circuit! 2003_GT 99-04 2 March 27th, 2008 11:11 PM
Carb Takes Fuel On One Side!!! GTXRacing General Tech 4 April 29th, 2006 05:40 PM
