2000 v6 mustang
![]() iTrader: 1 reviews
rusty fuel filler tube
well this weeks problem is that when i pump gas, it leaks but not anyother time
ive concluded that the fuel filler neck has rusted because the gasket is fine. has anyone done this? do i need to drop the tank to accomplish this task. also there is probably rust in my gas tank so how do i get the tank cleaned out i feel like im going to HAVE to drop the tank oh and where do i get this part? can i get it at a parts store or do i have to go to ford
![]() If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
I'm guessing it's either the rust on the filler neck, or the gasket that connects the neck and the gas tank. That went on mine when I was away from home and my tank was losing gas every time I took a turn so I had a shop fix that and the neck since it was rusty anyways. I think it was a total of $250 for parts and labor, and I dont think they had to drop the tank
EDIT: You might need to drop your tank Gas Tank Leaking?? How to Drop your Fuel Tank / Replace the Filler Neck Gasket
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome. ![]() |
2000 Mustang
Mac LTs, O/R H pipe all 2.5 inch piping, Flow 40s, 3 inch tips. Steeda short throw shifter, AM CAI, 3.73 gears, ford racing trac lock. 3 piece mach 1 grille delete, mach 1 chin |
2000 Mustang
ah just checked and they dont carry it in our year, sorry ill continue to look.
Probably a fuel filler gasket, not too expensive but they do have to drop the tank. Common problem on 94-99.
2000 v6 mustang
it should? how much you want for it?!?!
my gasket is fine because its clearly leaking before the gasket on the down pipe and plus the gasket is $20 bucks from ford so ill go ahead and get one when i do this anyways
Threads Similar to: rusty fuel filler tube
| Rusty Filler neck with holes? JB weld it! | EddieJr93 | 99-04 | 18 | February 6th, 2011 10:58 PM |
| Fuel Filler Tube Leaking | punisher0822 | 99-04 | 18 | December 14th, 2010 11:03 PM |
| Fuel tank filler help | fox4.6 | Modular Mustangs | 1 | June 27th, 2008 07:33 PM |
| Gas Filler-Tube Grommet Replacement? | firewire | V6 Mustangs | 2 | September 19th, 2006 11:57 PM |
