from 3.8 (1995) to 3.9 (2004) engine swap (fuel rail diference)
Old August 9th, 2011, 03:34 AM   #1
jorgeflores is on a distinguished road
well, iam installing a 3.9 in my old 95 stang... it used to have the 3.8 singleport (150hps).... so i wanted a lil more power and a newer engine... so i buy a 3.9 splitport 2004....
first i found that it haved de IMRC and i didnt know how to make it work so i delete de IMRC.... so NO PROBLEM...
but now i found this problem...
the 95 engine haved 13conectors and a return line and also like a fuel regulator..
and the 3.9 2004 doesnt have return line and have 14 conectors (so i have 1 harness free :/)
so i was looking for fuel rail diagrams from the 95 and the 2004 to check out how to make them compatible but i dont find nothing!!!
so please help me, i need a cheap way to solve this problem...
some questions
-why i cant just install the 3.9 2004 fuel rail? what would it happend if i dont have a return line in my old 95 stang?
-if it have any problem instaling de new rail, can i solve this problem if i change de fuel pump or something?
please help dudes!
Old August 9th, 2011, 03:40 AM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
You have to mod the fuel rail....
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old August 9th, 2011, 04:08 AM   #3
and what about the wiring? thanks for the photo, very ilustrative!
the fuel regulator is in the nut iosnt?
Old August 9th, 2011, 04:11 AM   #4
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
What do you mean connectors, on what exactly?
Old August 9th, 2011, 04:16 AM   #5
let me take some pictures and upload them for best info for ilustrative data
Old August 9th, 2011, 04:23 AM   #6
i mean harness...
Old August 9th, 2011, 04:31 AM   #7
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Use your stock harness, no need to swap them.
Old August 9th, 2011, 04:42 AM   #8
mmmm are u sure? sorry for aswing, but i was seeing the harness and the 95 have more pins than 04 :S
Old August 9th, 2011, 04:46 AM   #9
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Yep I'm sure.
Old August 9th, 2011, 03:17 PM   #10
Loki's Avatar
1996 V6
Loki will become famous soon enough
No need to mod a fuel rail & the 04 harness WILL NOT work, use your old one. You may have to swap some connectors over, though..
As for the fuel rail, pull one off of a Windstar van or an E-150 truck. Mine is from an E-150. The lines will connect on the drivers side towards the back, so you'll have to extend them
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod.
Need cheap parts? CLICK MEEEEEEEEE!! =]
Old August 18th, 2011, 01:23 PM   #11
Hey kyle, how i have to modify my fuel rail to fit o0n the new motor? Where is the return line in that picture?
Old August 18th, 2011, 04:47 PM   #12
Loki's Avatar
1996 V6
Oh, that's cool. Completely ignore my post and do it the hard way. Lol, enjoy!
Old August 18th, 2011, 07:42 PM   #13
qwiksilvermustang's Avatar
1999 Mustang Pony
Not even currently moving
qwiksilvermustang will become famous soon enough
TOp right of photo you'll see the regulator and return line coming off of it, easy mod to pull off esp for the guys with NE's wanting to put down some huge numbers
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's
Old August 26th, 2011, 11:14 PM   #14
dudes iam just at the final of my project and i coesnt know how to make the mod for the fuel rail, can i re-use de FRP shit from the 95 fuel rail of my old 3.8?
how can i reconnect the return hose to the FRP?
Old August 27th, 2011, 01:37 AM   #15
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Split port use returnless. So you have to put a different pressure regulator on it with a return built in. Or make a 'T' in the soft part of the rail and use that as your return.
271rwhp N/A V6
Suck it.
Old November 19th, 2011, 12:51 PM   #16
well, this old topic its going to be alive because now i have a very BIG question....
now i run out of clutch ):
or at least i think so, because like for a month start making horrible friction noises and yesterday morning it only doesnt move in any direction because the transmition its not engagging... anyway... so the most common answer is to change me clutch... but thats tmy question.... should i get a 1995 3.8 clutch? or a 2004 3.9 clutch? when i swap the motors y swap them completely, but i left the original 1995 5sped transmition on it.... soooo what clutch i most choose? or what the hell you reccomend?
thank you dudes
Old November 19th, 2011, 09:55 PM   #17
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old November 20th, 2011, 10:28 PM   #18
Run ur car, not ur mouth.
SON1C's Avatar
2003 Sonic Blue 4.6L
SON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of light
thank you dudes
english class
238rwhp/263rwtq
Drew's Build Thread
Old November 20th, 2011, 11:20 PM   #19
Skar Gone
Skargon's Avatar
1998 Mustang V6
17.27@76.66
Skargon will become famous soon enoughSkargon will become famous soon enough
Originally Posted by SteeD43 View Post
english class
Rude much?
1998 5 Speed, CAI, Exhaust, Rear Seat Delete.
Old November 21st, 2011, 09:33 AM   #20
Green_6er's Avatar
2000 Mustang 3.8
use the clutch from the year flywheel that you have.
Threads Similar to: from 3.8 (1995) to 3.9 (2004) engine swap (fuel rail diference)
1995 Mustang Engine Swap mustang3194 4V / SVT 132 February 26th, 2011 12:52 PM
Check engine light-Low fuel rail pressure? bandity2k00 99-04 23 August 12th, 2010 07:00 PM
split port swap.. fuel rail stangshane V6 Mustangs 2 May 28th, 2010 02:02 PM
1995 5.0L Cobra Mustang 5.4L Engine Swap 1995CobraSvtMaddux 94-95 16 August 3rd, 2009 09:01 PM
1995 engine swap! help!! lil_kout 5.0 Mustangs 12 July 8th, 2008 06:07 AM
