Port/Polish or Windstar
Old August 9th, 2011, 08:41 PM   #1
adryan's Avatar
2003 Mustang V6 Pony Edit
adryan is on a distinguished road
Hey guys,
Any idea on the the pros and cons when it comes to differences in benefits between porting and polishing the upper intake as opposed to installing the Windstar instead. I will be porting and polishing the lower intake and heads... still thinking/deciding on cam and phenolic spacer. I basically have my old engine complete so I can take my time and do a thought out build. TB, MAF, Injectors, Powder Coat/Chrome/Hight Temp Paint are also being considered. F/I thoughts may come after... not sure yet.
Thanks.
Adryan
2003 Mustang V6 Pony Edition | 1968 Mustang RS |1980 Datsun 280 ZX | 1977 Camaro with '85 Intercooler Engine | 1971 Cadillac 472 cu.in. (7.7L) Engine | 1973 Mustang 5.0 Ragtop
Old August 10th, 2011, 01:39 AM   #2
Jetflo's Avatar
2001 3.8L w/ 5spd
Jetflo will become famous soon enough
I've recently switched back from Windstar to stock for smog tests. The car passed which is nice.
The Windstar has the edge over porting the upper intake only, but it is not a huge margin. Data logging with an SCT Livewire shows biggest difference is in the relationship between mass air flow and rpm between 2500 and 3200 rpm and again between 4000 and 4600 rpm. In these areas, the Windstar just moves more air showing load values 0.03 higher (0.83 peak load at about 3000 rpm and 4500 rpm for Windstar and 0.80 peak load at about 4200 rpm for stock intake). In fact, the ported stock actually scores higher peak MAF flow values. Too bad it is at 5900 rpm when the engine is topping out.
If you do a cam (higher rpm) and valve springs, a ported stock intake is probably fine. If you are going with the stock cam (lower rpm), the Windstar has an edge. Porting still beats unmolested enough to be more than worth the effort.
Enjoy!
Are you absolutely certain you're not pregnant?
Old August 12th, 2011, 08:31 PM   #3
adryan's Avatar
Thanks Jetflo... so scientific with stats and all. It seems that depending on the application, the benefits are there but minimal in differences between the two. Would you recommend a larger TB and 24# injectors with the AM CAI and stock cams? I have moranoracing a few blocks away from work and he custom grinds cams and sells entire kits... with that I'm thinking that I will have enlarge air intake volume and fuel all throughout. (And he does recommend the appropriate internals for performance cams)
Old August 13th, 2011, 10:26 AM   #4
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
cams need pushrods usually. You probably wont know till its in the block. And valve springs/retainers. The ones comp cams recommends for their max street/strip cam is what you'll need.
Windstar is going to be your best option over a stock upper.
The stock upper to be properly ported to my knowledge has to be cut in half, inside must be ported all the way through. And welded back together. Or some shit like that.
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old August 13th, 2011, 11:03 AM   #5
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
If your going to buy a throttle body, just send me the money and I'll send you a sheet of paper that says "larger throttle body" tape it to the upper intake it will give you the same gains +/- 5rwhp. If you send another 20$ I'll sign it and it'll then give you +/- 12rwhp.**
Injectors + your mods also = waste of money
**doesn't count if your buying the windstar kit and doing the tb upgrade.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old August 13th, 2011, 11:23 AM   #6
Loki's Avatar
1996 V6
Loki will become famous soon enough
You mean this one?
COMP Cams: Xtreme Energy™, 273HR112 <BR> Max Strip & Street, Requires Spring
Then what roller rockers would you use, or does that not matter as much?
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod.
Need cheap parts? CLICK MEEEEEEEEE!! =]
Old August 13th, 2011, 11:32 AM   #7
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
What?
Old August 13th, 2011, 12:38 PM   #8
2004,1994,1967
14.37 @ 96
COMP Cams: 7° Steel Retainers: Stock Spring Dia.
COMP Cams: Beehive™ Valve Springs: Top 1.075" O.D., .650" I.D.; Bottom 1.310" O.D., .885" I.D.
springs/retainers recommended by comp cams.
227whp N/A V6
Old August 13th, 2011, 01:59 PM   #9
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
You don't even have 918s
Old August 13th, 2011, 02:16 PM   #10
2004,1994,1967
14.37 @ 96
i thought those were the 915s ops
227whp N/A V6
Threads Similar to: Port/Polish or Windstar
Port and Polish Kramer V6 Mustangs 10 May 24th, 2011 03:25 PM
DIY Port and Polish? maxium 96-98 26 December 26th, 2009 05:47 PM
Port n and polish or Windstar intake??? mustangv600 V6 Mustangs 22 July 20th, 2009 09:09 PM
windstar split port swap or port and polish winnie51189 V6 Mustangs 22 November 4th, 2008 04:04 PM
They Way To Port And Polish MustangMatt96GT The Clubhouse 13 November 11th, 2007 09:23 PM
