Formerly 01silversixer
2001 V6
15.47@89.57
Question for the boosted guys...
No this isn't a thread about my pipe dreams for my car (not yet atleast
)but this actually started from my friend and I discussing how to build his WRX (doing a hybrid 2.5 build if anyone knows anything about subarus). Anyways, what is a good turbo to run on a stock block 3.8? How about a built 4.2? But the real question is, how bad is the turbo lag? And how does it compare to something like a procharged car? I have a friend with a big turbo evo that is hitting over 30 pounds. And the lag is pretty bad, the car goes nowhere then just hits you in the face with boost, and is hard to keep in boost when driving. Are turbo v6s like this? Especially since I see guys running relatively large stuff, like 61mm turbos and such. Just curious pretty much, and thinking about where I would like to go with my car. |
#2 | |
2003 mustang
7.48x1.56=11.67
i'm running a 6262 .63 a/r on a 3.9l engine and it starts to spool around 2800rpm, full by 3500rpm. As far as lag, if you go with a 57mm ex wheel or gt30r, it will spool instantlly on a 3.8l. Dont have aby real data comparing my prochargr setup to the new turbo setup now. Both setups pull hard. I will say this though, pound for pound the turbo will out shine the blower. It took me 15psi and a cam to hit 400rwhp, where as the turbo would have hit 400rwhp on 15psi alone. So there is a parasitic drag with the blower.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
2000 Mustang 3.8
ehh w/e the mostly stock time is
also that evo had 4 exhaust ports and your car has 6. the more the exhaust, the faster it will spool (comparing the 2 with similar sized turbos)
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
2001 V6
15.47@89.57
I realize that green ^
I was just curious cuz I was looking at some of the dynographs on v6power and a lot of them didn't look like they were making full boost until almost 4000 rpm or higher. |
2003 mustang
7.48x1.56=11.67
One thing to keep in mind though, you will spool faster on the street vs spooling on a dyno because of load. Your car is under more load on the street vs the rollers. Also keep in mind that when your on a dyno you dont just punch it from a dead stop. Ususlly you get it up to around 2-3000rpm before you go wot on the dyno because you have to dyno in a higher gear(3rd for auto or 4th for manuel)
Also exhaust housing plays a big part in spool up. For a street car t3.63 a/r. For mostlly track t3 .82 a/r for a stock 3.8l. I would not go with a t4 housing unless I were shooting for more than 500rwhp. This is my prefrence and i know some will disagree with that statement, but to each their own.
2001 V6
15.47@89.57
Yeah thats true about the dyno thing.
If I wanted something that spools up quickly like a GT30R would you be choking the turbo in higher rpms? |
#7 | |
[8MINUS2]
Anyway, turbo lag beats not having a turbo... And a procharged car won't come anywhere close without more boost. Also OP, I don't know where you live but a 61mm turbo isn't large... People around here daily drive 70s and a few crazies DD 80s (supra guys and the crazy crowd in the 85mph buicks)
#8 | |
2001 V6
15.47@89.57
There is an 03 cobra with a 76mm. Anything else you will only see at the strip. |
2003 mustang
7.48x1.56=11.67
Your not going to choke on the top end with a gt30r and stock 3.8l. I'd go with a .82 t3 and you should be good for more than the stock engine can handle.
As far as spool, if you throw a gt30r on your car, you are gonna spool that sucker hard. I'd guess full around 28-3000rpm if not sooner.
2000 Mustang 3.8
enlighten me lol. I just thought that it made sense.
2003 mustang
7.48x1.56=11.67
displacement, headflow, c/r, etc...
4.2l v6 vs 4.6l v8...They could both spool a 60mm turbo around 2800rpm. On my 3.9l I can spool my 62mm wheel at 2800rpm.
#12 | |
2001 V6
15.47@89.57
Threads Similar to: Question for the boosted guys...
| Boosted guys - what oil do you use? | saxmanJJ | 99-04 | 27 | July 1st, 2011 05:27 PM |
| knowledgeable boosted guys come in | mystang0673 | 99-04 | 43 | December 24th, 2010 05:42 PM |
| Auto boosted guys come in | mystang0673 | 99-04 | 21 | December 14th, 2010 09:26 PM |
| Boosted Question | Kerns | 99-04 | 10 | July 19th, 2010 12:39 PM |
| What else do I need? Boosted guys Need help | Scott2001GT | 99-04 | 52 | December 6th, 2009 10:56 PM |
