2002 Auto V6
Several Seconds
P0420 code CES light on Exactly 1 Year after dual exhaust swap at Meineke
So after exactly 1 year of swap, my CES light comes on and autozone gives me the code P0420, What do I do keep in mind i live in new york and need to pass inspection
[U]Specs[/U] 351W EFI with 2 cylinder delete [U]Mods[/U] Catted dual exhaust with Flowmaster 40's H-piped $60 XM with no subscription Savings Account Mod $00000.00 [U]Future Mods[/U] None [COLOR="Red"]Put This Immature Crap Back In Your Sig, And You'll Be Taking A Vacation. Love, TheUNZippee!T[/COLOR] |
Dancing Naked In The Rain
Got this list from another forum. Possible causes:
Use of leaded fuel. Oil contamination. Cylinder misfiring. Damaged HO2S. Damaged ECT sensor. Downstream HO2S wires improperly connected. Fuel pressure too high. Damaged exhaust system pipe. Damaged exhaust manifold. Damaged muffler/tailpipe assembly. Damaged catalytic converter.
#3 | |
2002 Auto V6
Several Seconds
Honestly, I would put my money on the rear passenger (bank 1) O2 sensor being bad. You're probably at or past the point when O2 sensors are supposed to be changed (100k miles).
2002 Auto V6
Several Seconds
yeah im at 86k, but is it possible that the shop screwed up and a year later my exhaust goes bad, becuase i realized that my rattle also went away
I doubt it was anything caused by the shop. If they had damaged something, it probably would have been apparent not long after the work was done.
#7 | |
2002 Auto V6
Several Seconds
i also need to pass emissions
I've never had to deal with emissions so I'm not sure if high flows will pass but if they will and you get them, they may not clear up the problem (because it might just be that the O2 sensor has gone bad). But I'll let someone who has emissions in their state chime in about the high flows.
2000 v6 mustang
![]() iTrader: 1 reviews
why do people always wanna jump on the last shop to do work on their car even if it was a year ago...
working at a shop i see this alot..... and no its not the shop if its been a year. i imagine its something unrelated to the 02's because 80% of the time on our cars that passenger manifold will be cracked letting air into the system throwing off the 02 sensors readings. i had this EXACT code when mine was cracked
![]() If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
^ That's possible as well, and pretty easy to check with some soap and water in a spray bottle.
just wow about blaming the shop....
as for your issue...and you wondering about hi-flow cats...if they are marked OBD2 complient then they will work for emissions. as for your code clean off the driver side o2 sensors with a wire brush...reset the computer then do a drive cycle...you might get off lucky |
#12 | |
Threads Similar to: P0420 code CES light on Exactly 1 Year after dual exhaust swap at Meineke
| Noob question dual cats dual exhaust? | debar252 | 2005 - 2010 V6 | 4 | April 13th, 2011 02:46 AM |
| P0420 code | armygrunt18 | V6 Mustangs | 11 | April 9th, 2011 12:22 AM |
| Vid of the aftermath of the Meineke messup lol | Rich J | V6 Mustangs | 14 | June 20th, 2010 10:16 PM |
| SES light-code P1401 code-& DPFE sensor ?'s | PacificMustang01 | V6 Mustangs | 6 | May 18th, 2010 02:39 PM |
| Went to meineke.. | elijah | V6 Mustangs | 21 | August 28th, 2007 12:32 AM |
