Better than ONLYaUNCfan's
2012@lightspeed
Cutting steeda springs.
Want to go lower and dont want to buy new springs. Would it be bad to cut steeda competition springs? I need half an inch.
Formerly, AhobosCheese and Cheddars.
MM's Database Error
If they are linear springs, you can cut them. I don't recommend cutting springs ever though personally, but I won't go into that whole debate again.
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
#3 | |
@op...on stock springs I've found a coil off is an inch drop on average. Hope that helps even though yours are steeda |
2012@lightspeed
the problem.....steeda springs are very stiff so I dont know how much to cut for that little drop. No they aren't linear.
Priest of the Car Gods
You can cut progressive springs, too. The only difference is that when you cut linear springs, you know that the resulting spring rate is stiffer, which is necessary when you're decreasing the ride height.
OP - have you already removed your spring isolators? You can find 1/4"-1/2" more drop just by pulling those, just make sure to wrap your spring ends in electrical tape if you go that route. Also, why do you say you "need" another 1/2 of drop?
2012@lightspeed
Yes they are removed. I just need another 1/2 inch. I got the type of spring wrong they are linear sorry.
The spring rate is 850lbs.
#7 | |
2000 v6 mustang
![]() iTrader: 1 reviews
![]() If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
#9 | |
A metal of a certain diameter allows a certain amount of deflection with a certain length. If there's less length, there's less metal to deflect, and thus less deflection. For a simple experiment, try bending a pencil, and see how much you can flex it. Now cut that pencil in half, and see how much you can flex the shorter piece.
#10 | |
repped for the physics lesson
Threads Similar to: Cutting steeda springs.
| cutting springs | JD mustang | 2005 - 2010 | 21 | April 11th, 2011 10:09 PM |
| cutting my springs in FL... | delgadog | Southeast | 0 | December 29th, 2010 10:28 PM |
| cutting c springs | Blk01ponyGT | 99-04 | 13 | July 5th, 2008 08:31 AM |
| steeda sport springs or steeda comp springs | mustang2517 | 99-04 | 3 | April 3rd, 2008 07:27 PM |
