cant figure this out???
my 1998 V6 mustang has started acting funny
. I have a Mishimoto racing radiator that has no fill outlet i have to fill it through the upper hose so its hardd to know if its full or not but i think it is. Now what its doing is if i drive it...and not far, the ice cold air starts to get warm and the check engine light flashes. Now could it be the belt slipping or not enough antifreeze? its VERY annoying as im afraid to drive it anywhere because i dont want to damage anything. If any of you have a idea id love to hear it...Thanks in advance!
What do you mean by ice cold air? Your Air conditioner?
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome. ![]() |
2001 Mustang 3.8
Try taking off your belt, and make sure you clean, and dry every pully on the engine. Replace old belt with a new belt, and it should not slip anyfurhter.. If you still have problems, At least you have a new belt, and clean pulleys..
Dancing Naked In The Rain
Possibly a large air pocket in the coolant?
[8MINUS2]
I'm going to go with this answer here.
OP, you need to get an inline fill for the radiator.
Yes when i say ice cold air i am talking about my air conditioner. It goes from blowing cold to almost hot and the check engine light starts to flash on and off. If its a air pocket in the coolant how do i get rid of it. I have loosened the top hose and put fluid in till it came out the top of the thermoustat housing so other than that how would i fill it? thanks everyone for your help
I believe you need to loosen the screw on the overflow tube and run the car until bubbles stop coming out. I'll let someone else chime in to be 100% sure, I've never had to totally totally refill coolant.
1998 mustang v6
slow lol
check the tensor pulley mine was cracked on the back side and caused the belt to slip i realized it because my power steering was going out i thought pump but it was the belt slipping i lighley pulled on belt and the damn thing fell right off lol i was lucky it was at home replaced it and idler pulley while i was at
mustang 98 3.8 5 speed 17in akita wheels ![]() 98 gmc 1500 4x4 5.7 stock
2001 v6 premium
How can you tell if the system is properly filled if you have no filler neck on the radiator?
Why do you have a Mishimoto Radiator? Do you have any other modifications? |
OP, what are you doing for an overflow reservoir if you don't have a pressurized cap anywhere in the system? Also, you said you're getting a CEL...what is the code?
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
YEah you should definitely have a pressurized cap. Vehicles come with it for the reason that it pressurized the system and in doing so it lowers the boiling point of the the coolant. Adding one will probably solve your issues. You might be able to find an inline one at your local auto parts store just look on their websites.
i have no cap at all. It hasnt been a problem for a few months then this started. Will not having a cap cause the A/C to get hot all of a sudden?
Is the car overheating? If it is then the condenser is gettting hot from the radiator heat, which is raises the pressure in the A/C system. Your vehicle has a high pressure safety switch that disengages the A/C clutch because the pressure is too high. Get a line fill and put a radiator cap.
Here's one i found at autozone. Even if it isn't the problem, you should still have it. Dorman/Coolant Filler Neck (902-305) | AutoZone.com |
Here are some high quality and better looking ones.
coolant filler neck - Google Search |
By not having a cap, you not only have a hard time bleeding air from the system, but you also have no way of regulating system pressure. It may not be the source of your current problem, but it certainly is something that I'd remedy immediately.
Scan your codes and see what is setting off the CEL as well.
Threads Similar to: cant figure this out???
| can't quite figure this out... | Mach Stang | Forum Games | 0 | May 30th, 2011 01:02 AM |
| cant figure out what to buy... | mustangsoldier | 5.0 Mustangs | 29 | April 13th, 2009 10:48 AM |
| ok... so ive been trying to figure out what to do next. | tcasoccer13 | 4V / SVT | 66 | March 20th, 2009 09:49 PM |
| No one else can figure this out, but I know you can! | jkellam | 94-95 | 7 | October 8th, 2008 11:36 PM |
| cant figure it out | ttop5.0 | 5.0 Mustangs | 2 | August 26th, 2006 06:54 PM |
