LinkBack (1) | Thread Tools |
#1
2000 v6 mustang
![]() iTrader: 1 reviews
rear main seal leak.
alright... well my rear main seal leaks pretty good.... and i want to replace it.
i work at a dealership and am going to BEG them to let me do it in the shop on my day off. but if i cant i just want to know if anyone has done this on jackstands. since i have to lower the transmission i am weary to do this in my garage lol alot of the work i do is on a lift but this time it seems like noone will help me out. so basically if anyone has done this without a lift then let me know how you did it and if there is anything i should know. auto trans btw
![]() If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
1996 V6
I had my car up on jack stands.. Remove driveshaft, put a car jack under the tranny (In a spot with good weight distribution), unbolt tranny (Keeping it jacked high enough so it stays wedged to the bottom of the car. Lol).. & do the work. Just be careful, I guess. There are probably easier ways to do it, but I'm not one to sit there and think on things too much
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod. Need cheap parts? CLICK MEEEEEEEEE!! =] |
2000 v6 mustang
well i think if i had a friend i could pull the tranny out of the way completly... i just donno, will i have to drain the trans fluid for this?
I've always dropped the trans completely so I had room to work. You'll lose some fluid when you disconnect the trans cooler lines, but there is no need to drain the trans.
And I've always worked with jackstands. I wish I had a lift.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
1996 V6
Might leak a little out of where the driveshaft goes, but as far as tranny fluid, that's it. And as Tang Stang said, your trans cooler lines since ur an auto
2000 v6 mustang
ok so jackstands as high as you can get them? and drop it down onto some sort of rolling thing lol like a creeper or furniture dolly?
i think im getting more comfterable with the idea of doing this in a garage lol
2001 Mustang 3.8
ok.. i did this with a friend in my drive way.. lmaoif i knew how to upload picutures, i would show you everything!!
2001 Mustang 3.8
hey.. heres was my little project!!
Car jacked up: ![]() Shot at 2011-08-17 My trans: ![]() Shot at 2011-08-17 My rear: ![]() Shot at 2011-08-17 my clutch pressure plate: ![]() Shot at 2011-08-17 |
2000 v6 mustang
yeah i have an auto trans.... the R&R time according to all data is like 2 hours more than for a standard
idk why but im sure if i get into this ill find out lol
2001 Mustang 3.8
I believe in you... you can do it.. if not ... ummm... you can do it
2000 v6 mustang
i like this new guy. dont let these guys beat u up about ur grammar in ur other thread lol fuq emm!!
2001 Mustang 3.8
#13 | |
[8MINUS2]
Without a lift just take the DS and remove the trans, car on jack stands, and then you have 2 options a.) being a badass and muscling the transmission onto your stomach and then off or b.) transmission jack then r&r and go in reverse
#14 | |
2000 v6 mustang
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/229914-rear-main-seal-leak.html
| Thread Rear Main Seal | Nissan Xterra Forums | BoardReader | This thread | Refback | August 22nd, 2011 06:48 PM | |
Threads Similar to: rear main seal leak.
| Rear main seal leak will i pass tech inspection?? | black88 | 5.0 Mustangs | 4 | May 4th, 2011 04:32 PM |
| Possible Rear Main Seal Leak??? | wrr1020 | 99-04 | 4 | April 4th, 2011 09:16 PM |
| rear main seal | bandity2k00 | 99-04 | 15 | March 15th, 2011 09:50 PM |
| Rear Main Seal | 02GreyStallion | V6 Mustangs | 16 | January 21st, 2011 01:58 PM |
| Rear Main seal | 1gunner23 | 5.0 Mustangs | 5 | May 11th, 2006 11:53 PM |
