![]() iTrader: 1 reviews
Advice on tire pressure
I have p225/16 tires on the front, p235/16 tires on the back of my mustang, 2" eibach drop on front, nothing on rear. Is it ok to put all four tires at around 35-36 psi? Thats what I have all four at right now. Or if not, what do you recommend?
I'm doing it wrong
04 Grand Cherokee
I recommend whatever is engraved on the tire... Honestly.
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
What do you mean? Usually thats something like 44 psi, overkill!
I'm doing it wrong
04 Grand Cherokee
Then round down to 40. But 35-36 psi is fine, just as long as your car doesn't wobble when it gets up to speed your good.
I run 35 daily and when I go to the track if it wasn't prepped good I will go down to 30 psi
2003 mustang GT vert
35 psi is fine, you could go for 40 to get better millage, just be sure you are not exceeding the limits, I have my 265/17 at 40 psi Ive taken it to the track at 18 psi on the back, worked great !
V8, I6, V6.
Dancing Naked In The Rain
I think 35-36 would be good. Although it depends on how hot it is when you fill them up. If you fill them to 35psi when it's 105* outside, the pressure is going to drop quite a bit at night if the temp drops down into the 70s or whatever. Air expands in the heat and contracts in the cold and it will do it inside your tires, so keep that in mind when you put air in them.
1996 V6
WRONG! What's on your tire is the MAX PSI, & SHOULD NOT BE FILLED TO THERE!
If anything, you fill from what it says on the inside of your door sill. Fill it to 35-36, you'll be fine.
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod. Need cheap parts? CLICK MEEEEEEEEE!! =] |
#8 | |
Follow the tires recommendation. Some low profile tires need up to 50 pounds of air. Look at the max pressure on the tire and go 5 pounds less. Tire pressure will increase as you drive due to the air in the tires expanding.
Black and White Crew ![]() Crew Member # 3 centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie |
1lb up or down for every 10degrees in air pressure change as well
Does the tire size matter.....??? Cause inside my door its written 35psi for 225/65/16.....and im running 275/35/18's....?????
The difference between Fiction and Reality??? Fiction has to make sense. -Tom Clancy |
2000 Mustang 3.8
ehh w/e the mostly stock time is
go by what it says on the side of the tire and put about 5 - 8 pounds less in it.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
That is good info to know. And come on guys. Tires have come a long way in the past 10 years. If you have a new edge the pressure recommendation was for tires that are pretty much extinct now. Plain and simply put follow the tire manufacturers recommendations. Unless your driving a 2012 mustang the door psi recommendation doesn't really apply. If your really concerned I suggest using 35 pounds as a start then drive around noting the handling characteristics then add 2 pounds til your happy with performance but remember that as you drive the psi will increase so make sure your dialing it in with warm tires. As they cool the psi will go down but don't add more air.
I keep my BFG KDW2s at 32 psi cold.
#16 | |
2000 sixxer, 1988 Fox
At the OP, 35psi in your tires, the size difference makes no difference in the tire pressure you run.
Priest of the Car Gods
If you want the scientifically accurate answer to this, you're gonna have to learn to take tire temps. Buy a cheap pyrometer (I got mine for $30), go for a drive, and measure the temperature of your tires at the outer shoulder, center, and inner shoulder.
Basically, if you know how to read tire wear, reading tire temps is pretty much the same, you just treat "hotter" as "more worn" and you don't have to wait until the tires are shot to see where the problem is. If you don't, here's the digest version: *If the center is hotter than the shoulders, you have too much pressure. *If the shoulders are hotter than the center, you have too little. *If the outer shoulder is hotter than the rest of the tire, you need more negative camber. *If the inner shoulder is hotter than the rest, you need less negative camber. Hot individual shoulders could also be due to incorrect toe. Also note that there should be a slight gradient across the tire, with the inner shoulder being slightly warmer than the center which should be slightly warmer that the outside shoulder - this is due to the outer shoulder being more exposed to fresh air, which cools it down.
32 psi cold for the majority of street tires... trust me.
^ this. Almost every average size car calls for 32 psi
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
As already said the number listen on your tire is the MAX psi. so many pppl make the mistake of filling it up to this number.
I usually run 35psi up front and 30psi in the back. on 255/35/19
2004 Bolt on & Cammed 3.9L V6 |
Threads Similar to: Advice on tire pressure
| Tire pressure for 555r on street? (Tire life) 23psi max? | 01MGGT | 99-04 | 13 | December 1st, 2010 01:54 AM |
| NEED HELP!!! Tire Tire Pressure Sensor Fault!! On | Mr.Stang08 | 2005 - 2010 | 7 | March 7th, 2009 12:14 PM |
| tire pressure | petyweestraw | General Tech | 1 | February 25th, 2009 01:18 PM |
| tire pressure | BORDEN | Drag | 4 | August 30th, 2008 01:29 AM |
| Tire Pressure? | orlyr21 | V6 Mustangs | 4 | February 23rd, 2007 05:47 PM |
