Help..code p0153
LinkBack (1) Thread Tools
Old August 17th, 2011, 03:57 PM   1 links from elsewhere to this Post. Click to view. #1
2001 mustang v6
StubzStang is on a distinguished road
Help..code p0153
Hey guys I'm having a few problems.
Code p0153 - o2 circut slow response (b2,s1)
what could be causing this?
and
My car is also idiling around 12-1500rpms after getting warmed up. Are these 2 problems related?
'01 3.8L
Old August 17th, 2011, 04:01 PM   #2
eleanorGT's Avatar
2001 Mustang 3.8
eleanorGT will become famous soon enough
i had sort of the same problem.. Try replacing your front two(Up stream) o2 sensors.. This should do it.. The back 2 o2s are useless.. they just let your computer know that you have cats for inspection. Hope this helps.. They should cost 47.99 if you buy from auto zone..
Old August 17th, 2011, 04:55 PM   #3
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
i told you that eleanor
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old August 17th, 2011, 04:57 PM   #4
eleanorGT's Avatar
2001 Mustang 3.8
Ive learned well........
Old August 17th, 2011, 06:27 PM   #5
2001 mustang v6
i've already ordered a new sensor but could a malfunctioning o2 sensor be causing my high idle?
'01 3.8L
Old August 17th, 2011, 06:33 PM   #6
Green_6er's Avatar
2000 Mustang 3.8
clean your iac and see if it fixes the high idle.
Old August 17th, 2011, 10:16 PM   #7
2001 mustang v6
^done..still having high idle issues. It only happens after the car is warmed up though.
'01 3.8L
Old August 17th, 2011, 10:43 PM   #8
eleanorGT's Avatar
2001 Mustang 3.8
Yup... o2s will fix this... let me know after you put them in... i had the exact same problem, and the front o2s fixed it... if not try cleaning the MAF.. if anything seafoam her, and switch to all sythetic oil if your not already runnin with that..
Old August 18th, 2011, 09:12 PM   #9
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
What o2's did you go with?
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old August 18th, 2011, 09:46 PM   #10
Green_6er's Avatar
2000 Mustang 3.8
it is either your O2s or your tps is about to go.
Old August 18th, 2011, 11:58 PM   #11
eleanorGT's Avatar
2001 Mustang 3.8
TPS???
Old August 19th, 2011, 03:51 AM   #12
2001 mustang v6
motorcraft
it will be here tuesday
'01 3.8L
Old August 22nd, 2011, 06:03 PM   #13
Look Ma! My First Post!
jimvit1 is on a distinguished road
I would put my money on the TPS as when mine started going out I would get and irratic idle speed until it started failing big time then it was a fast idle all the time.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/230156-help-code-p0153.html
Thread P0153 code | Ford Explorer Ranger Enthusiasts Serious Explorations® | BoardReader This thread Refback February 3rd, 2012 09:56 PM
Threads Similar to: Help..code p0153
DISCOUNT CODE DELETED - New Code Available - Please Read! AMNick American Muscle 86 May 14th, 2012 08:22 PM
P0153 code Kadorja 2005 - 2010 2 August 12th, 2011 11:10 PM
p0153 code driving me crazy xslobcorex 99-04 0 August 15th, 2010 05:27 PM
SES light-code P1401 code-& DPFE sensor ?'s PacificMustang01 V6 Mustangs 6 May 18th, 2010 02:39 PM
p0133 and p0153 HELP!!! russell16 99-04 4 December 15th, 2008 01:11 AM
