98' V6 Fuel Pump
Old August 17th, 2011, 09:20 PM   #1
95ish5.0
SSteady98's Avatar
1995 GT
Slow
SSteady98 is on a distinguished road
Send a message via MSN to SSteady98
98' V6 Fuel Pump
This has probably already been a topic of discussion, but I've used the search function and found nothing, and so I'm asking in a thread.
Here lateley(the past 3 months) I've been having to crank my ignition over about 3-8 times to get it to start properly. I think its the fuel pump, but I'll be replacing that and the fuel filter at the same time. The question is this though; does the v8 pump work on the sixxer? I don't want to be out 130$ if it only work son the GT. Also- if theres anyone who knows the best place/price to get one that will work and not break within a few months, link me to that.
Another question. this is far from the fuel issue. My hood, resulting from a deer hitting me, flew off a couple months back. I had to buy a new one, and it needs paint. what is the best way to do this? It is dark green(pacific green, i suppose) and I don't enjoy having a rust looking hood. Any tips, links, or pictures will help.
AND ANOTHER THING. size of pipes for a v6 to run on duals? I plan on making a self fabbed kit with my dad. Sizes of echos as well is needed.
and LASTLY.
(By now, you're probably like WTF DUDE, use the search function for these stupid as@#$()* questions)
Is it worth it to put 3.73s and tloc in the stock v6 rear end? Wanting to get that going since 1 wheel peel makes my other tire just bald. I want some more traction! and about traction bars, dont need those do I?
Thanks in advance, your help is appreciated.
1995 Mustang GT
BBK Shorty Headers, H Pipe, CAI, UDP, 255lph Fuel Pump
Spec Stage 3 Clutch
FR500's all the way around
Cobra R Hood
*Want*
Gears, Cam, TW Heads, Turbo(Last)
Old August 17th, 2011, 09:28 PM   #2
eleanorGT's Avatar
2001 Mustang 3.8
eleanorGT will become famous soon enough
ok.... i am not sure about the GT fuel pump working on a V6, but i know the fuel pumps from CJ pony parts, or AM are great... In regards to your T-lock or gears.. Go T-lock.. if you going to get both, install both at the same time.. no need to pay for 2 installs.. Or do what i do, and jack her up yourself and go to town.. your chioce... good luck man!
Old August 17th, 2011, 09:35 PM   #3
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Buy an OE pump.
List price OE parts.
http://www.newfordparts.com/ifrm_browse.php
271rwhp N/A V6
Suck it.
Old August 17th, 2011, 09:53 PM   #4
04Sixxer's Avatar
2004 'Stang v6
04Sixxer is on a distinguished road
and LASTLY.
I would just get an OEM replacement pump. Getting a gt pump won't help you unless you plan to do upgrades to the car that will require more fuel. I believe the gt pump flows more.
Not really sure about the paint but you might not want to try it yourself unless you have a lot of painting experience. That's a large area and if it's hard to describe the color it will be really hard to match it.
Most people say 2.25 or 2.5 inches in diameter for the pipes and no larger than 3". I have 2.25" pipes and they're just fine.
If you do both gears and a t-lok do them at the same time, which has been said already. However it depends on how much power you want to make in the future. If you will eventually be making quite a bit more than you are now, then you would be better off getting an 8.8 with gears. If you will stay close to where you are now power wise, then just install them into your 7.5 and it will hold up just fine. The 7.5 is quite a bit lighter as well
Divorced Duals with Thrush Welded Mufflers
93 Octane BAMA Race Tune
Stack Racing Air Intake
Kicker Comp 12" Sub/JL Audio Amp
6000K 55W HID's
Originally Posted by Cathedral View Post
Then I'd get Zach Galifuckunucks to play me in a movie.
Old August 17th, 2011, 09:55 PM   #5
95ish5.0
SSteady98's Avatar
1995 GT
Slow
Originally Posted by Mr. Red Pony View Post
Buy an OE pump.
The pump itself is 400$ through them? O.o
1995 Mustang GT
Spec Stage 3 Clutch
Cobra R Hood
*Want*
Old August 17th, 2011, 09:55 PM   #6
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
GT doesn't have a bigger pump... It pumps the same volume at the same rail pressure.
271rwhp N/A V6
Suck it.
Old August 17th, 2011, 09:57 PM   #7
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Them try Rockauto.com
271rwhp N/A V6
Suck it.
Old August 17th, 2011, 09:58 PM   #8
95ish5.0
SSteady98's Avatar
1995 GT
Slow
Thank you for the response, rep added. I wasn't wanting the gt pump, but AM was specifying it for V8 usage. Awesome on the paint- i put clear coat on myself and it held up. after a while though, it just came right back off, though. I may watch a few guides.
Do you know how much the piping would be for the kit? And with the rear end, I doubt I'll end up making more than that. Honestly though, I'm in between on it. I just definitely want a set of matching tires, along with a "working" car that doesn't have fuel problems.
1995 Mustang GT
Spec Stage 3 Clutch
Cobra R Hood
*Want*
Old August 17th, 2011, 10:00 PM   #9
04Sixxer's Avatar
2004 'Stang v6
Oops, my bad. That's pretty interesting that they both pump the same amount though.
6000K 55W HID's
Old August 17th, 2011, 10:04 PM   #10
04Sixxer's Avatar
2004 'Stang v6
No problem, all the piping for my exhaust ran me at about $200-250. But then again, the only shop i found that was close and would do it was a Meineke, so they probably way overcharged me. It's all mandrel bent so maybe that's why. Hell who cares, I just know it sounds good
6000K 55W HID's
Old August 17th, 2011, 10:07 PM   #11
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
lol for 250 you got a good deal. i paid 300 for all of the piping, mufflers, and labor for mine.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old August 17th, 2011, 10:10 PM   #12
04Sixxer's Avatar
2004 'Stang v6
Haha you're the one that got a deal! $250 dollars was for the piping alone. Labor and mufflers were another $300
6000K 55W HID's
Old August 17th, 2011, 10:12 PM   #13
Green_6er's Avatar
2000 Mustang 3.8
haha but then again i got the mellotones (generic flows) and i had tires put on when i had my exhaust done so i think they gave me a lil discount lol.
Old August 17th, 2011, 10:20 PM   #14
95ish5.0
SSteady98's Avatar
1995 GT
Slow
Ouch. Yeah hopefully it wont be that much. But then again, I may just stick with fixing the pump and buying the deep dishes i want. then when i get my spring return for college ill invest 4-5k$ into a GT, put those wheels on there, and start working on it.
1995 Mustang GT
Spec Stage 3 Clutch
Cobra R Hood
*Want*
Old August 17th, 2011, 10:20 PM   #15
95ish5.0
SSteady98's Avatar
1995 GT
Slow
but THIS is what I want, right?
BBK Electric Mustang Fuel Pump Kit - 255 LPH (86-97 V8) at AmericanMuscle - Free Shipping!
1995 Mustang GT
Spec Stage 3 Clutch
Cobra R Hood
*Want*
Old August 17th, 2011, 11:12 PM   #16
MustangV6Man? can only hope to improve
I got mandrel bent divorced duals with two flow 40's and the whole pipe job and install was $200, the mufflers were obviously about $100 each retail.
Threads Similar to: 98' V6 Fuel Pump
Intank fuel pump installation on fuel injected Mustangs, 1987-2004. Cobraman1024 Articles - Engine, Other 0 May 4th, 2011 09:02 PM
8-9lbs boost gt500 fuel pump 47lb or 80lb fuel injectors? justin503 2005 - 2010 8 March 7th, 2011 01:41 AM
Boost-A-Pump or GT500 Fuel Pump? stanglifemike 2005 - 2010 64 September 21st, 2009 01:17 PM
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 02:25 PM
