Army Strong
It's a standard ^_^
Air conditioning
My ac works just fine at max. Just wondering that when I change it to the direction of the footwell it gets warm and not cold. Is that normal?
95 5.0L COBRA
95 COBRA
yea, mine use to blow cool-warm if not on ac or max ac. after i changed a/c clutch it it cool even when on vent or floor vented!
Joe
Not All Who Wander Are Lost. ![]()
Army Strong
It's a standard ^_^
Thanks man. And where is the ac/clutch located
95 5.0L COBRA
95 COBRA
in front of compressor. its the thing with 3 blot looking knobs on it. un screw bolt in front wile holding clutch. then clutch plate will come out. then there is a round lock washer you un clip. then pull whole pully off!!!!! takes like 10 min. really. 99 bucks at auto zone.
Joe
95 5.0L COBRA
95 COBRA
Army Strong
It's a standard ^_^
Thanks again. And help you lol your helping me bro
2000 GT 'vert
this is bad advice..
The A/C clutch engages ONLY when the A/C is on A/C or Max A/C. When you put the selector on Vent, the clutch is disengaged as the compressor is not used/needed. If you change direction to floor or defroster, does it not work? There are other threads regarding this type of failure and it's got nothing to do with the A/C clutch. EDIT: You're problem is probably something to due with the vacuum system located in the dash.. I've got a huge headache and don't feel like searching, but here is a thread that might give you some key words to look for a resolution. A/C won't blow out vent a/c and heater vents not working!!!
"...but don't say my car's topless, say the titties is out" Nas Last edited by bigjohnstud4200; August 18th, 2011 at 08:44 PM. |
Army Strong
It's a standard ^_^
The ac works just fine just wondering if it were meant to blow cold air down to the floor
#9 | |
2000 GT 'vert
You have likely lost the vacuum supply to the blend door(s). I think there are 3, one for defrost, one for main vents and one for the floor but I can't verify that fact. You need to trace the vacuum lines that run from the a/c and heater control unit, out into the engine bay. You either had one break or come out of the nipple" |
95 5.0L COBRA
95 COBRA
just a thought from what ive experenced, im still learning!
I Cannot chase down this problem! plz advise!
Army Strong
It's a standard ^_^
Thanks man! Ill take a look at it
#12 | |
2000 GT 'vert
2000 Mustang 3.8
ehh w/e the mostly stock time is
i have a fix that takes like 10 - 15 seconds. turn fan speed to 1 then turn a/c to vent, then roll both windows down. problem solved.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
#14 | |
Im pretty sure the Defroster cycles the AC too. The vent/floor won't use A/C though.
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome. ![]() |
2000 GT 'vert
Yeah, I believe you are right.. in order to reduce humidity in the air.
It makes my wife horny
16.3@84@5kft
to pull moisture out of the a/c system, fail safe for winter.
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k 1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21 2004 Nissan Armada - HIDs, LEDs, sippy and DVDs 2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
2000 GT 'vert
yeah yeah.. what he said!
Threads Similar to: Air conditioning
| Air conditioning | EasternRider1990 | 5.0 Mustangs | 1 | July 16th, 2010 07:36 PM |
| air conditioning ftw | flattusmaximus78 | 5.0 Mustangs | 0 | August 30th, 2009 01:30 PM |
| air conditioning | v8muscle | 5.0 Mustangs | 3 | August 14th, 2009 11:52 AM |
| air conditioning | v8muscle | 5.0 Mustangs | 4 | August 6th, 2009 07:34 PM |
| air conditioning | Easy04_jm | General Tech | 1 | April 26th, 2006 03:23 PM |
