need help car wont start
Old August 22nd, 2011, 12:13 AM   #1
fastpony's Avatar
1998 ford mustang gtclone
fastpony is on a distinguished road
Send a message via AIM to fastpony
Was cleaning the car with the radio on, i finished up and went to put car in garage. Turn the key and click. car wont start. i checked the car terminals, took em off cleaned em reconnected the battery, click. i noticed the theft light would blink once when i turned the key back to off. When i had my door open, and tried to turn the car on the dome light would flash on and off repeatedly. i also noticed that when the key is in on, i can move the auto through gears with out touching the brake.... i hooked up my aunts explorer, thought it was possibly bad battery, waited a bit and turned the key and click.
Old August 22nd, 2011, 12:16 AM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Try charging it a bit longer?
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old August 22nd, 2011, 12:33 AM   #3
Modded V6
Stang6899 is on a distinguished road
How long have u had the battery?
1999 e46 328i BMW - Daily Driver
2001 SVT Cobra - Project
1995 v6 vert - SOLD
1996 v6 vert - SOLD
1995 v6 vert #2 - SOLD
1995 GT - SOLD
1997 v6 coupe - Parting
Old August 22nd, 2011, 12:51 AM   #4
fastpony's Avatar
1.5 years.
but went back out and the theft light is flashing in unicin with the dome light.
Old August 22nd, 2011, 01:09 AM   #5
Modded V6
Are your headlights bright?
1995 v6 vert - SOLD
1996 v6 vert - SOLD
1995 GT - SOLD
Old August 22nd, 2011, 01:12 AM   #6
fastpony's Avatar
nothing will come on accept dome but just barely
Old August 22nd, 2011, 01:17 AM   #7
DEFIANT's Avatar
01 GT
DEFIANT will become famous soon enoughDEFIANT will become famous soon enough
Get a new battery. Problem solved.
[ d I [] fa I [] nt ]
Old August 22nd, 2011, 01:43 AM   #8
Jailbait till 2013
whyxitx's Avatar
2001 V6 / 94 Z28-gone
0-60 in -10.3
whyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to behold
battery is dead. Try jumping it and see if it'll turn on.
I Removed My Door Dildos
Originally Posted by bullitt1680 View Post
Whyxitx's sixxer is so fast that the side scoops come off when he drives. How could anyone say that isn't fast.
2001 V6 - Needs faster engine
1995 Human - Needs BJ
Old August 22nd, 2011, 02:09 AM   #9
fastpony's Avatar
Wrong, i just swapped the battery out with my uncles and nothing.
I should be clear on the head lights. If i disconnect the battery and reconnect it. and if i turn the key to the on position, but not start. everything works until you try to start the car. after you attempt that, the car goes into a safe mode i think to where noting works.
Old August 22nd, 2011, 08:10 PM   #10
2003 Roush Mustang Stage1
Therealtater is on a distinguished road
do you have another key? try that, it may be your security system
Old August 22nd, 2011, 08:45 PM   #11
fastpony's Avatar
dont have another key, but i routed a ground wire from the battery (neg) to a bolt that hold the alternator to the bracket and the car started right up. im thinking i just bypassed the system though... once i take the wire off, the same problem occurs.
Old August 22nd, 2011, 09:14 PM   #12
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
probably a ground problem then.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old August 22nd, 2011, 09:25 PM   #13
No its the security system my uncles car had the same probably back in April when you go straight from the battery to the starter you bypass the security system, without another key I don't know how to fix the problem without going to Ford
Old August 24th, 2011, 01:27 PM   #14
fastpony's Avatar
So I was able to get the car started and got it to a shop. Had to run a ground wire from the neg battery to a bolt that hold the altenator to the bracket. So I had the shop run a diagnostics test for me.. Two codes came back. Don't remember the codes but the first was for a bad transceiver( four wires that run from the ignition to the pats system are malfuncioning) and the second was for the key. The guy at the shop said the transeiver is a common issue on mustangs if they won't run.
Old August 24th, 2011, 07:27 PM   #15
Told you it was the security system glad to know you found out what was wrong with it though
Threads Similar to: need help car wont start
Wont start ....AGAIN! 1sl0w88 5.0 Mustangs 3 October 10th, 2010 03:57 PM
[HELP] Wont Start deadbolt 5.0 Mustangs 6 January 14th, 2010 06:49 PM
Car wont start ballajb 5.0 Mustangs 1 November 18th, 2009 01:30 PM
car wont start.. soop7 V6 Mustangs 3 December 1st, 2007 03:18 PM
