2004 Mustang v6
Would i be fine with a 7.5 differential
Only looking to make 250-260 hp with future turbo. Would a 7.5 differential be strong enough for this power or would it be best to go with 8.8 right off the bat.
14.37 @ 96
I blew my 7.5 w/ stock power
some have taken the 7.5 to 300-400 hp or more. I mean it would be stupid to keep it stock with that power, you'd want to put a posi in it and some gears ... But other then that it would really depend on how you drive it. So on that note, yes It *could* be fine for that much power And btw, I cant remember, are you a auto or manual ? |
2004 Mustang v6
manual, i would just rather be safe than sorry and pay a little more the first time so nothing happens. fast-reliable no cheap
14.37 @ 96
how deep are your pockets then ?
2004 Mustang v6
What would be the difference in price between 7.5 and 8.8
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
Usually you can find an 8.8 for 150 bucks on craigslist.. then throw gears in it.
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
Dancing Naked In The Rain
This. Because it already has a tlok.
14.37 @ 96
parts + install close to the same
8.8 should hold up better though |
2003 mustang
7.48x1.56=11.67
You dont have to swap the 7.5 right off the bat before you start to mod, I didnt. I run the stock unit for a good 4 months before I put the detroit locker in it.
Put the power mods on it first and go from there.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
2004 Mustang v6
Will I need anything besides the 8.8 and gears to have it put on?
2000 Mustang
slow@slow
and its super easy
2001 3.8L w/ 5spd
I did not see two things mentioned here:
1. 8.8 weighs about 70lbs more 2. 7.5 and 8.8 differ only in the pumpkin, axles and shafts are identical Either axle has its advantages. The 7.5 will take a lot of power if you don't drive like Ace Ventura, Pet Detective. An 8.8 can take more power but adds weight. The choice is yours . . .
Are you absolutely certain you're not pregnant?
2004 Mustang v6
im not drag racing, so ill take the 8.8. I found this one, if its not the correct one i need what am i looking for?
2004 Mustang v6
2001 3.8L w/ 5spd
To use that 8.8 TLok you will need to get an 8.8 axle assembly. What you saw on ebay is the correct part for Mustangs that came with 8.8 rear ends.
I'm not sure why you'd pick the 8.8 if you are not drag racing. Its main advantage is being able to launch more brutally without breaking. In street use, the extra weight just requires more gas to move and makes it harder for the suspension to keep the rear tires on the ground. Google "unsprung weight" to learn more about how it affects a car's handling.
1996 V6
Neither one is correct. The second is just the tlok & I think the first is, too..
Your best bet is either junkyards or craigslist. A rear end is not something you want to order as shipping will have your wallet's ribs touching it's spine. Lol
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod. Need cheap parts? CLICK MEEEEEEEEE!! =] |
Priest of the Car Gods
If you're not drag racing, that's more reason to stick with the 7.5, not to go 8.8.
#19 | |
[8MINUS2]
1996 V6
^ I was thinking the same thing. I think it's more in the 30-50 range.. From what I've heard, anyway..
Threads Similar to: Would i be fine with a 7.5 differential
| These Injectors would be fine right? | Nicos2001GT | 99-04 | 7 | September 28th, 2010 10:39 AM |
| I think I would fit in just fine | dr.gonzo! | The Clubhouse | 0 | August 25th, 2010 04:06 AM |
| A Fine Explaination | WAR-PARTY | The Clubhouse | 14 | July 28th, 2010 08:41 AM |
| Pay your fine | ItaliStang | Forum Games | 70 | March 12th, 2010 09:49 AM |
| Another Fine GM Product | TurboLX | The Clubhouse | 16 | November 16th, 2007 02:48 PM |
