Discussing V6 Info... The Bible of sixers in the V6 Mustangs Forum. Well first of all I posted this so It can help ppl out and know ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#1 | |
2000 Mustang V6
Well first of all I posted this so It can help ppl out and know how do they match-up
1. Ford: 1.a 94-98 Mustangs: 1.a Engine specifications: 3.8L 145 hp V6 Horsepower 145 @ 4000 RPM *note 96-98 +5 h.p Torque (lb-ft) 215 @ 2750 RPM Valves/Valve Configuration 12/OHV Displacement (cc) 3802 Bore X Stroke (in.) 3.81 X 3.39 Compression Ratio 9.0:1 Fuel Type/System Gas/SEFI 1.b 99-04 Mustangs: 1.b Engine Specifications: 3.8L 190 hp V6 Horsepower 190 @ 5250 RPM Torque (lb-ft) 220 @ 2750 RPM Valves/Valve Configuration 12/OHV Displacement (cc) 3802 Bore X Stroke (in.) 3.80 X 3.40 Compression Ratio 9.3:1 Fuel Type/System Gas/SEFI 1.c 05-07 Mustangs 1.c Engine Specifications 4.0L 210 hp V6 Horsepower 210 @ 5300 RPM Torque (lb-ft) 240 @ 3500 RPM Valves/Valve Configuration 12/SOHC Displacement (cc) 4009 Bore X Stroke (in.) 3.95 X 3.32 Compression Ratio 9.7:1 Fuel Type/System Gas/SEFI 2.Toyota 2.a 94-99 Celica: 2.a Engine Specifications ST GT 1.8L 110 hp I4 | 2.2L 135 hp I4 Horsepower 110 | 135 @ 5200 RPM Torque (lb-ft) No data | 142 @ 4400 RPM Valves/Valve Configuration No data |16/DOHC Displacement (cc) 1844 |2198 Bore X Stroke (in.) 3.27 X 3.3 | 3.39 X 3.72 Compression Ratio 9.0:1 | 9.5:1 Fuel Type/System Gas/EFI |Gas/SEFI *Note 96-99 has a decreased of 5 h.p and an increas of 2 in torque in the 98 and 99 models the 1.8 was not equiped they all had 2.2L... 2.b 00-05 Celica: 2.b Engine Specifications ST GT 1.8L 140 hp I4 | 1.8L 180 hp I4 Horsepower 140 @ 6400 RPM | 180 @ 7600 RPM Torque (lb-ft) 125 @ 4200 RPM | 130 @ 6800 RPM Valves/Valve Configuration 16/DOHC| 16/DOHC Displacement (cc) 1794 |1796 Bore X Stroke (in.) 3.11 X 3.60 | 3.23 X 3.35 Compression Ratio 10.0:1 | 11.5:1 Fuel Type/System Gas/MPFI | Gas/SEFI 3.Chevy 3.a 93-97 Camaro: Engine Specifications: 93-95 96-97 3.4L 160 hp V6 |3.8L 200 hp v6 Horsepower 160 |200 @ 5200 RPM Torque (lb-ft) 200 |225 @ 4000 RPM Valves/Valve Configuration No data | 12/OHV Displacement (cc) 3392 |3785 Bore X Stroke (in.) 3.62 X 3.31 |3.80 X 3.40 Compression Ratio 9.0:1 |9.4:1 Fuel Type/System Gas/SEFI |Gas/SEFI 3.b 98-02 Camaro Engine Specifications: *They are the same as the 96-97 Camaro 4. Hyundai 4.1 97-2001 Tiburon: Engine Specifications *Note the 97 was the only one with the 1.8L option Base FX 1.8L 130 hp I4 | 2.0L 140 hp I4 Horsepower 130 @ 6000 RPM |140 @ 6000 RPM Torque (lb-ft) 126 @ 4200 RPM | 133 @ 4800 RPM Valves/Valve Configuration 16/DOHC |16/DOHC Displacement (cc) 1794 |1975 Bore X Stroke (in.) 3.11 X 3.60 | 3.23 X 3.68 Compression Ratio 10.0:1 | 10.3:1 Fuel Type/System Gas/EFI | Gas/MPFI 4.2 03-06 Tiburon: *Note 04-06 has h.p increased by 2 on both engines compression and bore X Stroke got change just a lil bit Engine Specifications Base GT V6 2.0L 134 hp I4 | 2.7L 170 hp V6 Horsepower 134 @ 6000 RPM | 170 @ 6000 RPM Torque (lb-ft) 132 @ 4500 RPM | 181 @ 4000 RPM Valves/Valve Configuration 16/DOHC |24/DOHC Displacement (cc) 1975 | 2656 Bore X Stroke (in.) 3.22 X 3.68 | 3.41 X 2.95 Compression Ratio 10.3:1 | 10.0:1 Fuel Type/System Gas/MPFI | Gas/MPFI Well people this is all for now later I'm gonna add more cars and 1/4 mile speeds hope this info can help you out. If you want me to post more info like car weigth specific makes/models tell me I want this to have all the Info of V6's so people will know how do they match-up... Ohh I'm also gonna try to post in suspension and other info that can be consider valuable....... -Louis Alexander (El_Cangri)
1 Fast wheelchair
1989 MUSTANG LX 5.0
To slow to matter...
Umm this is all well and good but what the heck does a tiburon's engine specs have to do with a V6 mustang? This is the V6 tech forum not other makes and model forum.
SUPPORT YOUR LOCAL HOOKERS.... FLASH A TOW TRUCK DRIVER! Donate to lxhatch@gmail.com
The George Forman of Keepers
I think its interesting because alot of tiberon owners like to try and get "tough" at stop lights. I like to know what Im up against... and Im lazy so I rarely leave the V-6 forum. I think its good data where ever its posted.
GHOSTANG 2273 ![]() What? |
MM's Resident Ricer
2006 Scion tC
13.9@103/8.9@81
i think it is more see where the v6 stands in correlation to other v6's
#5 | |
2000 Mustang V6
Turp I just posted this so the mustang v6 owners can know how they matchup with other cars cause all I see is people saying that our's v6 are the slowest... With this people can learn something.... Maybe some people think Tinuron are faster well they r not.... I want to inform other people...
¡ʇsnq ɹo uʍop ǝpısdn
thanks dude... so i don't need to much more to own my friends maro? thats nice to know thanks dude
#7 | |
2007 Mustang GT/CS
Re: V6 Info... The Bible of sixers
#8 | |
#9 | |
v6 Mustang GOD
2k2 Mustang V6
2000 V6
Ha ha i love racing maros
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
v6 Mustang GOD
2k2 Mustang V6
Yeah their fun now, but Stock v Stock .... Ewww
2000 V6
When I was stock i could take the 3.4's...and the 3.8 were always a good race...now I use em as ego boosts after losin a race
#13 | ||
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
from half of 00 most 99-00 hav same crank set up 01-04 have slight different crank design if you've notice if you've ever looked into or bought underdrive pulleys but the only power difference is the 3.9L 2004 V6 |
MM's Resident Ricer
2006 Scion tC
13.9@103/8.9@81
stock for stock with equal drivers the mustang will win.
2000 V6
Yeah and we look better doing it
#16 | |
2000 V6
More than likely...my auto vert has taken a few 00 maro's
hmm good to know
#19 | |
v6 Mustang GOD
2k2 Mustang V6
The 3.8 camaro S4S w/perfectly equal drivers will win 99.8% time The 3.4L can ALMOST keep up with a 99-04 v6 mustang... v6cam > v6 stang z28 > mach 1 / 99-01 cobra ss < 03 eaton cobra
#20 | ||
MM's Resident Ricer
2006 Scion tC
13.9@103/8.9@81
v6 stang > v6 maro z28 ls1 > gt, and 99-01 cobra ss=z28 same car different appearance package they might as well be equal cars.
Threads Similar to: V6 Info... The Bible of sixers
| Why do sixers wanna sound like a V8? | 2000Mustang | The Clubhouse | 39 | September 22nd, 2007 10:55 PM |
| do sixers talk about stupid shit or | Onemanzu | The Clubhouse | 9 | September 11th, 2007 11:34 PM |
| How many sixers live in the south east? | dapack69 | Southeast | 13 | September 9th, 2007 09:32 AM |
| for you sixers! | WAVEBYE | Videos | 13 | February 20th, 2007 09:21 PM |
