01 true blue GT
LT install help!
Hey guys my pacesetter LT's came in the mail two nights ago and im going to install them tommorow, any advice from you guys with LT's? Ive gone to every shop within 30 miles from me and not one will touch them so im stuck doing it myself, it'll be a good learning experience i guess
so anyway any advice would be great, i planned on installing them and then using a flex pipe until i get to my friends house with a welder that can weld the piping in for me, sound good? Thanks in advance
![]() 00' V6-basics, mostly visual, missed! SOLD 01' GT True blue, bbk CAI, slp lm1 catback, tinted tails, HIDs, tokio blues, chin spoiler, clear fogs, 18x9/10 chrome saleens wrapped in nitto 555's, MMD fuel door, more to come |
Formerly 01silversixer
2001 V6
15.47@89.57
I had to disconnect the drivers side steering shaft to get the header up there.
The job is a lot easier if you have a friend to help. |
2001 Mustang V6
+1 invest in a friend. if u have no friends invest in beer and they will come.
just be patient try finding a lift. u can do it on the ground under jack stands but it blows. they arent going to slide up there in place. took me 6 hrs start to finish and i have to remove all of the stock exhaust. autos require trimming the trans to fit. possible steering shaft disconnect. i didnt have too if u do discoonect it make sure the steering wheel doesnt move. egr tube is a bitch unless u delete it. had to cut a $20 wrench to tighten it up sidenote: i dont know if a tuner is required for lt's but the oxygen sensors do move farther downstream so the reading will be different than stock. also u will need O2 extenders for the front O2 sensors and if u run the rear ones u will need them too. this is what i used as a guide longtube install v6 |
2001 V6
15.47@89.57
Don't have to trim the trans with mac longtubes. And I used a small plumbers wrench to tighten the egr. I did it on jackstands, took maybe 5 hours
01 true blue GT
thanks guys and i have a few friends helping, so hopefully its not to bad, and i have to trim the trans? Really?
#6 | |
2001 Mustang V6
@op it is possible. u will to see when u install. |
01 true blue GT
alright ill check it out when im installing, ill come back if i need anyhelp, tearing down tommorow night, going to try and have the intake out, the spark plug wires out, and that damn egr removed. Ill post pics as well!
The soul stealing Ginger
i snapped my egr pipe in half while doing this mod. overall it was pretty easy and i didnt have a lift. did it on jackstands and some patience.
01 true blue GT
thats how i plan on doing it, taking all saturday to do it, no rush
14.37 @ 96
you guys are making this hard :p
atleast in my 04 it was pretty simple. Driver side LT went down from the top pretty easy. Passenger side needs to come up from the bottom. So jack the SOB up high. Now I cheated and didn't have my engine bolted down, so I jacked it up about 2 inches and made that passenger side ALOT easier. Have problems with it ? I suggest you take off the two nuts on the motor mounts and jack the engine up a little bit ! And yes friends make it alot easier ! |
14.37 @ 96
BTW you do know that pacesetters need to be repainted dont you ?
They dont come with high temp paint on them ... You dont have to paint, but it sure makes things nicer if you do |
Threads Similar to: LT install help!
| lca install | walkerman180 | 2005 - 2010 | 45 | May 28th, 2011 08:22 PM |
| header install/un-install problem | Tank86 | 5.0 Mustangs | 4 | April 2nd, 2011 02:37 PM |
| DDM install Help | Maverick530 | 99-04 | 27 | December 2nd, 2010 06:07 AM |
| cam install | jerseymike | Modular Mustangs | 17 | June 27th, 2009 06:47 PM |
| Help with install | medic_chris85 | General Tech | 5 | November 21st, 2008 09:21 AM |
