95 5.0L COBRA
95 COBRA
Jobra wont stay running...just happen 1 hr ago?
Hey guys its me again! lol 5 days ago i replaced my fuel pump with a 255 high pressure pump. car was running GREAT! iMy wife and i pick up my boy and take him tho the Dr.s'. When we leave jobra started fine then 30 seconds later it died? then started back up.....Died. finnaly after 6-8 tried we made it back to the apts??!!!
What i have did was; 1. opened the air intake (right before the MAF) and as the engine tried to die i put my fingers across intake and kinda spread'em. the engine liked that? little high pitched noises from MAF and after it dies theres other little noises. My fuel psi is good. its getting gas...why do ya think i can mess with intake and adjust the ratio my self? and why did this just happen outta nowhere? Joe
Not All Who Wander Are Lost. ![]()
95 5.0L COBRA
95 COBRA
Ran for a second...thought i heard a little thump and it ran fine....started around complex..no power bogged every thime i pressed gas?.. then had to put around complex back to mine
. so again here what it is doing!!!
2003 mustang
7.48x1.56=11.67
Any codes?
po190 would be fuel pressure on the rail error if your getting that code.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
95 5.0L COBRA
95 COBRA
NO CODES lol i do have M.I.L. eliminators but thats for the o2z
95 5.0L COBRA
95 COBRA
Fuel filter?? again? i did install a new pump maby i need a new filter because of new deb-re?
[8MINUS2]
Sounds like you have a vac leak.
edit: or something much worse!
95 5.0L COBRA
95 COBRA
where can i find a diagram of vac layout? 98 3.8l ? what do ya think about the fuel filter?
[8MINUS2]
Fuel filter isn't causing that....
01 True Blue v6
to slow to matter
If it wasn't doing it before the fuel pump install, but its doing it now, then I would recheck the fuel pump, its connectors, and lines inside the hat. What fuel pump did u put in?
Modded V6
![]() iTrader: 1 reviews
![]() 1999 e46 328i BMW - Daily Driver 2001 SVT Cobra - Project 1995 v6 vert - SOLD 1996 v6 vert - SOLD 1995 v6 vert #2 - SOLD 1995 GT - SOLD 1997 v6 coupe - Parting |
95 5.0L COBRA
95 COBRA
wallbro 255
95 5.0L COBRA
95 COBRA
See thread before this one on my profile. my problem was the fuel pressure it was pushing 30-35 psi. After i installed walbro 225 pump everything was perfect and had more power. I started it this morning fine!! haven't drove it yet
95 5.0L COBRA
95 COBRA
How Could it be?.. I started jobra this morning and let it run and though hmmm, got in drove around complex and tried to die when i accelerate but sounds like running outa gas, eng almost not even turning BUT eng turning like 3k rpm ish.
Got back to parking place and started again. it bobbled to ok idle. when given gass it starts to lagg out. I started tapping on little things, EGR, TPS, lil throtal valve canister thingy in back. Engine Didnt sound much different idle than before tapping, but i hit the gas and it ran. Drove it around complex (after Video) and had 100% power??!! WTF? Joe
It makes my wife horny
16.3@84@5kft
you have some weird luck. you had something loose i think?? im not sure.
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k 1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21 2004 Nissan Armada - HIDs, LEDs, sippy and DVDs 2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
95 5.0L COBRA
95 COBRA
I have a back up, lol
96 Dakota 2.8l flat black costumed lights 10' lift in back, stock front height, lol. its a toy! but reliable! So....I guess i'm going to put old fuel filter back on to see if that is my problem.... <the pump i bought was walbro 225 high pressure fuel pump> * DO you think too much pressure can cause this? * Car starts every time, so pressure is there and pump hums. Also wouldn't i throw a code like stated above? or ...... symptoms sound like the alarm/fuel cut off system is activated??"""""" Joe
16.3@84@5kft
if yoiu can blow through the fuel filter its fine.
that pump wont cause that. if it does it again spray the vacuum connections with some brakekleen or something similar. if the idle changes you found your leak. im pretty sure its vacuum or electrical related. is there a lot of squirrels out there? maybe one tried to nest in your car at some time and chewed up some wires.
95 5.0L COBRA
95 COBRA
LOL, I can fiddle with the air intake right before maf, if i restrict air flow a little i can keep eng running!!! if left open it dies?
hmmmm
95 5.0L COBRA
95 COBRA
Got a CEL!!!! havnt read it yet (wont stay started to drive)
It happen i guess when i was reving eng with my fingers spread over air intake.
95 5.0L COBRA
95 COBRA
getting a voltage meter todaya and testing every thing...
I thiink... A. Stator(PIP sensor) B. M.A.F. C. ECM (im going to tap it wile running!!!) car starts everytime but won't stay running?!
95 5.0L COBRA
95 COBRA
Nothing..... guess im going to have to put it in the shop?!!!?? grrrr
Threads Similar to: Jobra wont stay running...just happen 1 hr ago?
| wont stay running?? | NASTYWHITE93gt | 5.0 Mustangs | 4 | August 28th, 2011 05:57 PM |
| Car wont stay running. | Jhoward93 | 96-98 | 2 | April 18th, 2011 10:21 AM |
| help car wont stay running and lacks power | svtcobra041 | 5.0 Mustangs | 7 | May 21st, 2010 02:51 PM |
| car wont Stay running | 01dutchGT | Classic Mustangs | 8 | April 23rd, 2008 02:42 PM |
| Car wont stay running | Spiderz | Classic Mustangs | 10 | March 8th, 2008 08:14 AM |
