windstar kit install help
hey guys i put my kit on finally and thought i did everything right but i guess not i have a bad leak coming from under the windstar intake idk i assumed i was suposed to use the blue gaskets that came with it is that right? also any advice to what maybe causing the leak?
2004 3.9l, O/R H with pacesetter L/Ts and flowmaster 40s,s/d coil pack, spec stage 2 clutch, 93 octane tune, msd wires, chin spoiler, black out vinyl, 8.8, 3:73s and tlok, windstar with custom fenderwell cai, dropped 1.25 in back and 1.5 in front
2000 sixxer, 1988 Fox
Did you torque it down correctly? I think there's a pattern you're supposed to use, maybe.someone else can shed a little more light on it
i think i did it correctly i dont know about any pattern so if anyone knows let me know please
Resident badass
Port & Polish Intake Manifolds
Scroll down for torque sequence. Are you sure its from the bottom? Did you hook up every vacuum line?
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
ya its coming from the bottom around the middle of the intake all the lines r hooked up and hose clamped i dont know how the gaskets work should they sit over the lower intake ports or in them? sorry if i sound dumb im still learning
14.37 @ 96
their are groves in the intake that the gaskets set in ...
14.37 @ 96
should be a figure 8 shaped gasket. But both halves are shapped differently. Make sure they are in the correct slot
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
If it's a high pitched whistle.. Torque the throttle body/spacer down
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
its a his and the idle drops im going to try to use the torque specs see if i can fix it thank you everyone for the help
The soul stealing Ginger
any luck?
1 Wheel Peel
2000 Mustang 393w
If torquing them down doesn't work, you may have torn one of the gaskets..
14.37 @ 96
Operator Malfunction
im going to try and finish today thank you guys
Threads Similar to: windstar kit install help
| windstar install | Bram-Stangg | V6 Mustangs | 36 | February 15th, 2011 12:55 PM |
| Help With Windstar Install | southfour! | V6 Mustangs | 74 | September 3rd, 2010 12:17 AM |
| 99 03 Windstar Install | 99 BLUE V6 | V6 Mustangs | 31 | August 20th, 2010 03:59 AM |
| Windstar install | moddedstang93 | V6 Mustangs | 12 | May 20th, 2010 12:57 PM |
| Windstar install time | Mr. Red Pony | V6 Mustangs | 61 | April 16th, 2010 01:04 AM |
