Need a little help
Hi, i have a 99 v6 mustang (red) and when i start it in the morning lately it starts rougher than it used to, and after backing out of my driveway i put it in 1'st and it bogs pretty hard for about 3 seconds, after that its 100% fine and normal.
This just started happening the last 3 weeks. |
Resident badass
Does it happen by just putting it in gear, or when you start to take off?
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
when you start to take off in 1st, and reverse is usualy fine for backing out 20 feet, then 1st is like fuckyou... oh wait nvm lets go..
Resident badass
Manual right? And it bogs down? Does it run rough?
5 speed standard, bogs only as you push gas in 1st for the first time in the morning. Runs awesome otherwise can burn rubber NP at any time other than that first time.
Resident badass
Try letting the car idle for a few minutes and see if it still does it. Just a though. But I can't thing of anything. Once you leave you house, is it a while before you are back into first gear? Try going from a stop repeatedly while leaving. Just get it to bog down, stop, then try to get it to do it again. Then report back.
im pretty sure if i let the car idle for a few mins its fine, also, it lasts so shortly that you cant repeat it, its just the first time.
Resident badass
You you can stop right while it does it, then do it again?
How long has this been going on? What is your mileage? Down you have any strange noises?
101k km's, its been happening for about 3 weeks.
its about a 2 second bog id guess, doesnt matter if u let up and start again. if you take the time to completely stop and start again its fine by then. only noise is a crappy startup now, kinda chugs like it struggles, this has been happening the exact same time as the bog started. I have an exhaust leak on the right side as per usual. |
