LinkBack (1) | Thread Tools |
#1
Resident badass
pushrod length checking
When I set the checker to the length they machine shop said it would be and tighten the rocker down, the valve compresses a little. Is this suppose to happen? I can put the stock PR in there with the rocker tight and I can wiggle just a hair, so I know its too short.
So how do I check the length properly?
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
14.37 @ 96
buy a PR length checker, put it to stock length. Stick it in there. expand.
Resident badass
Expand until what?
14.37 @ 96
until the checker is the correct length ?
Resident badass
No shit. When is it the right length. Do you put preload on it?
Use a pushrod length checker to find the length for zero lash, then add .020-.060". That length will provide proper lifter preload.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
14.37 @ 96
always wondered, are the instructions on that for new lifter, or used ones with pressure still inside them ?
As long as the lifters are in good condition, it doesn't matter if they are new or used. The spring inside the lifter will hold the plunger at the top of the bore so that you can find zero lash.
14.37 @ 96
Hell I Set them at 0lash and ordered those lol
Not Banned
Step 1: Take a Sharpie and make the top of the valve black
Step 2: Adjust the PR checker to stock height Step 3: Check valve lash with PR checker at stock height Step 4: Turn the PR checker making it longer until you get zero lash Step 5: turn over the motor 2 times with the pr checker in place and the rocker torqued down Step 6: Take off the rocker and see where it made a mark on the valve stem, you want to make it as close to the center of the valve, if its is not in the center adjust the PR checkers height up or down as needed. That is how i did it more or less i hope it helps a little bit Oh and do it on cylinder 1 starting when it is at TDC This was my first time doing anything with the motor and it took a good 2 hours doing this to make sure i got it exactly right. |
Resident badass
Well my concern is that I set the checker to stock, tighten the rocker. And I only get MAYBE 1/4 a turn..
2001 v6 premium
Interesting info. Will be doing my cam soon, and this is a question I had. I need to find a local place to get pushrods in stock so I am not down a week waiting on them to come in.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/231399-pushrod-length-checking.html
| pushrod length checking | This thread | Refback | September 2nd, 2011 03:04 PM | |
Threads Similar to: pushrod length checking
| Pushrod length | Wilhelm | 5.0 Mustangs | 4 | July 21st, 2011 07:02 PM |
| Pushrod length help | 91_FOX | 94-95 | 1 | June 5th, 2011 10:21 PM |
| pushrod length | StckFox | 5.0 Mustangs | 4 | August 16th, 2010 01:41 PM |
| Pushrod length | Burn'nRubber | 5.0 Mustangs | 5 | March 9th, 2009 07:23 PM |
| Pushrod length need to know? | dreamr | 5.0 Mustangs | 3 | October 17th, 2007 12:24 AM |
