Jailbait till 2013
2001 V6 / 94 Z28-gone
0-60 in -10.3
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Car is throwing codes.
SES light went on monday afternoon after normal driving.. i got these
P0172 and P0175, bank 1 and bank 2 are running rich. My car seems like it's driving normal.. but when i reset the computer, the SES is still on. What do you guys think? 02 Sensors? the guy at Adv. Auto said fuel injectors.. |
2000 Mustang 3.8
ehh w/e the mostly stock time is
same acceleration? any different smells? etc?
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
Jailbait till 2013
0-60 in -10.3
Pretty much
My cars felt uber slow since i put my new wheels and tires on though. That's just because they're a lot heavier then the stockers i think. everything smells the same too.. |
I'm doing it wrong
04 Grand Cherokee
Its always better to run rich than lean... But I have no idea what it could be. Sorry.
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Jailbait till 2013
0-60 in -10.3
thanks for the help, rich
lmao.i've also heard vacuum leaks could be it too.. i'll have to go check it out. |
2000 Mustang 3.8
any of your friends have a 99-04 v6?
Jailbait till 2013
0-60 in -10.3
by "friends" You mean kids at my school.. yes.
2000 Mustang 3.8
pop their hood and take one of the O2's and swap it with your too see if it is your O2's.
Jailbait till 2013
0-60 in -10.3
lol, they prolly wouldn't want me near the insides of their hood..
2000 Mustang 3.8
just tell them to stfu and pop their hood
Jailbait till 2013
0-60 in -10.3
i shall... lol.
Jailbait till 2013
0-60 in -10.3
i'm smelling gas, and acceleration is piss awful.
It makes my wife horny
16.3@84@5kft
i would guess your cats are plugged. if you are crafty and want to experiment, drill a 3/8" hole all the way through your two rear cats and clean off your o2 sensors.
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k 1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21 2004 Nissan Armada - HIDs, LEDs, sippy and DVDs 2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
Jailbait till 2013
0-60 in -10.3
never heard of drilling a hole through cats before,
but i'll give it a shot. and i'll do the o2 sensors as well just for the hell of it while i'm down there.
I'm doing it wrong
04 Grand Cherokee
Definitely sounds like a clogged cat. Just get rid of them and be done with it.
2002 V6
My check fuel cap light came on after reading this thread and leaving to go to school....My caps on tight.... Somethings up lol
![]() Selling Chrome Black Saleens + Mustang GT4 Rims http://www.moddedmustangs.com/forums...al-pickup.html |
I'm doing it wrong
04 Grand Cherokee
Your in the Northeast, around here (and places where winters can be harsh) the seal for the filler neck to the gas tank rots away.
#18 | |
MM's king of Neon's
404 - car not found
17.81@87
It could be injectors cycling more than they should, it could also be a bad HOS. However a bad HOS could be caused by fouling due to excessive rich mixture, and this can also cause fouled cats. Drilling out cats is a bad idea. They're expensive. Get an O/R pipe if you're concerned. First thing I'd do is clean the HOS's and test them. Fouled cats may be a symptom of the problem, but they are not the problem. If it was just bad cats you'd get a catalyst efficiency code, not a rich code. If the sensors are good and you continue to get rich codes, it could be injector related.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
You dont have an email tune right?
i had the same codes for half a year before i got a better tune. Did you try an replace your upstream o2 sensors? i doubt on a stock tune you would be throwing this code unless theres something wrong with your o2's. A car running a stock tune should not throw a rich code if everything is running right. How many miles are on your car? i would replace the o2 sensors before messing with the cats. Do the cheapest thing first...o2's usually go bad on these cars once you have 100k+ miles anyway.
2004 Bolt on & Cammed 3.9L V6 |
#20 | |
Jailbait till 2013
0-60 in -10.3
Threads Similar to: Car is throwing codes.
| throwing 3 codes | BDaily | 99-04 | 3 | February 21st, 2011 08:21 PM |
| throwing codes. tell me what needs to be done to fix. | dalton96gt | 96-98 | 14 | June 18th, 2010 01:52 PM |
| throwing codes | ZoomZoomMFer | 99-04 | 6 | June 24th, 2009 09:19 PM |
| still throwing codes :( | shadow5403 | The Clubhouse | 9 | May 5th, 2008 01:39 PM |
| still throwing codes :( | shadow5403 | V6 Mustangs | 0 | May 5th, 2008 12:17 PM |
