Timing
Old May 22nd, 2007, 08:58 PM   #1
99v6stang's Avatar
99v6stang is on a distinguished road
Timing
Is the timing the same as the spark advance? Because i was told that my timing was off and thats why i have such little power. And i have been planing on getting a sniper tuner and was wondering if that could fix my problem as well.
Old May 23rd, 2007, 11:31 AM   #2
stephen has a spectacular aura aboutstephen has a spectacular aura about
There are three types of timing:
1. Ignition timing is the same as spark advance.
2. valve timing is controlled by the timing chain and gears.
3. The fuel injection timing is controlled by a cam position sensor.
I presume they were talking about ignition timing. That is controlled by the computer and a TDC sensor near the front crank pulley.
I don't know about the tuner device, which I presume changes parameters in the computer.
Old May 23rd, 2007, 11:32 AM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
and to answer your other question.
Yes the sniper or Xcal tuners can change your timing
Old May 23rd, 2007, 09:36 PM   #4
99v6stang's Avatar
okey so if i am suffering from pathetic power at low rpms and i was told it was cause by the timing, a tuner would fix it?
My car ---- (m112 in progress)
Old May 23rd, 2007, 09:39 PM   #5
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
if is caused by timing yes.
Threads Similar to: Timing
need timing help bad!!!!!!!!!!!!!!!!!!!!!! sloppyjosey 5.0 Mustangs 18 October 23rd, 2007 05:34 PM
More Re-timing help 97redgt Modular Mustangs 1 September 9th, 2007 08:24 PM
timing punkafi888 V6 Mustangs 13 March 29th, 2007 01:01 AM
need help on my timing????? tag team 5.0 Mustangs 3 March 26th, 2007 12:04 AM
Timing weems 5.0 Mustangs 10 October 13th, 2006 11:26 PM
