2002 v6 stang manual
Stalling to start
I have one important ? I been wondering my car has been stalling when I turn the key to start ive asked my mechanic but everything he tried hasnt worked
2005 Mustang 6cyl
I"ve been having trouble with my engine bogging down on me while driving. I've had suggestions that it might be the MAF sensor. After reading up on it, I noticed that one of the symptoms of a bad sensor is stalling at start. You might check that.
Ive checked that they said it makes lose hp if its dirty but its pretty clean
2000 Mustang 3.8
ehh w/e the mostly stock time is
might be bad gas, or some buildup in your fuel system. seafoam it and see if it gets any better.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
Whats seafoam ? & how u do that ?
2000 Mustang 3.8
There are numerous threads about seafoming. Use the search feature. Also, learn how to type proper English.
Resident badass
Define stalling. Like starting slowly, or starting, then immediately dying?
If it is starting slowly, get you battery tested. If the battery is good, you have something dragging. Take you belt off (just off the crank pulley. No need to take it completely off.) and if it starts normal speed, then an accessory is dragging. Start hand spinning pulleys until you feel one drag.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
Like to start the battery is good
The soul stealing Ginger
I dont think i would try seafoam if its having a problem starting. if its stalling at startup seafoam might keep it from turning it over seeing as how the car try to start with seafoam in the lines. unless its just in the gas.
vaccuum leak?
UDP, Cai, MAC LT's, Divorced duals with original 40's, Predator performance tune |
What a vacum leak ?
It makes my wife horny
16.3@84@5kft
those little rubber hoses that are all over the top of your engine are vacuum hoses. one of those might be disconnected or corroded, causing a leak in the intake system. do you have a check engine light on?
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k 1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21 2004 Nissan Armada - HIDs, LEDs, sippy and DVDs 2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
No I dnt I just cleaned my air control valve like this guy on here told me & it worked
How do u find a vacum leak?
Threads Similar to: Stalling to start
| still stalling on cold start | mattabater | 2.3 Mustangs | 6 | March 4th, 2011 04:24 PM |
| The car was stalling | 89Bullitt | 2.3 Mustangs | 0 | September 27th, 2010 08:16 PM |
| stalling | terribleonexx88 | 5.0 Mustangs | 2 | March 21st, 2008 11:47 AM |
| 98 gt Difficult to start and stalling | 98 gt stang | 96-98 | 8 | October 12th, 2007 10:50 PM |
| should my car be stalling/surging on cold start with a cam? | WhiTeFoX5point0 | 5.0 Mustangs | 4 | August 26th, 2006 12:42 PM |
