2010 Mustang V6
Hey, new heree but I have a problem w/ AC fan and wipers on '10 v6
Hi, not sure if I'm posting this in the right place, but I seem to be having a intermittent problem with the wipers, washer fluid and AC fan in my 2010 v6. Recently I went to squirt the washer fluid and noticed it didn't work, I tried the wipers and they didn't work, I also noticed that the AC fan wasn't going. Once I got home I started the car again and everything worked fine. Just went to the dealer, but they could not duplicate the problem, they checked the fuses for issues, moisture etc and found nothing, no TSB's either. then this morning it happened again, this time I shut the car off and restarted it and of course everything worked as it should have. I have a Bama 93 race tune but that shouldn't affect this (other than being a pain to restore to stock every time I go for service). Otherwise I've done nothing to the car. I'm thinking a bad relay, I'm still under warranty and I need to get this fixed (it rains a lot here in FL!) but I really don't want to have to keep taking time out of work to go to the dealer. Any ideas?
The soul stealing Ginger
2005 - 2010 V6 Forum
I would go here from now on to post, just because those guys over there have the same car as you. Welcome to Modded Mustang!!!!!!!!!!! * queue horns and trumpets* No seriously, I would check to see if the wipers and windshield fluid sprays are on the same fuse/relay, more than likely is the culprit, AC fan could be of some separate issue. Does the ac fan, wipers, and squirters work find at the same time and then not work at the same time? |
#3 | |
2010 Mustang V6
Haynes manual has pretty good diagrams on wiring. maybe Ford could give you a print out from their parts dpt to.
2010 Mustang V6
Threads Similar to: Hey, new heree but I have a problem w/ AC fan and wipers on '10 v6
| wipers being gay | liljojo4711 | 99-04 | 12 | August 26th, 2010 02:43 PM |
| wipers | Mustang RacR94 | V6 Mustangs | 1 | April 26th, 2007 05:05 PM |
| Wipers | MustangMatt96GT | 96-98 | 3 | March 10th, 2007 12:01 PM |
