New Rotors. RED HOT!!
Old September 20th, 2011, 09:42 PM   #1
roth515's Avatar
2004 v6 mustang
roth515 is on a distinguished road
I put new rotors/brakes on this past weekend. I broke a bolt on the passenger side rear caliper. After taking apart everything from the back side ( rotor bolts and e brake spring) i was able to get the rotors changed. After changing rotors and trying to put the calipers back on i noticed they would just pull the rotor inwards. This happened on both sides. I reassembled them both twice and every time i put the calipers on it would just cause it to happen.
I thought i could just put the wheels on and bolt them on and it would just push the rotor back straight. But After a quick test run the rotors were red hot and smelt horrible.
Any ideas what i could be doing wrong?
Old September 20th, 2011, 09:44 PM   #2
roth515's Avatar
2004 v6 mustang
Oh and this was only the rear rotors, which i also replaced the guide pins and bolts for the calipers
Old September 20th, 2011, 11:07 PM   #3
did you replace the broken bolt? just curious since you never mentioned that
Old September 21st, 2011, 09:13 AM   #4
roth515's Avatar
2004 v6 mustang
Yeah, all bolts were replaced with new ones from a kit from advance auto.
It was all new guidepins and bolts
Old September 21st, 2011, 10:44 AM   #5
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
check the pads, see if its grinding down on only one side of the pad. maybe its sitting in their at an awkard angle.
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old September 21st, 2011, 10:50 AM   #6
roth515's Avatar
2004 v6 mustang
The front pad(outboard) is tight against the rotor, the rear side pad (inboard)is really loose i can get my finger in there and move it around..
Old September 21st, 2011, 10:52 AM   #7
2001 Mustang 3.8l
what about the outer pad?
Old September 21st, 2011, 12:01 PM   #8
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Are you certain you have the correct rotors? Did you compare the dimensions of the new rotors to the old ones?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old September 21st, 2011, 12:25 PM   #9
roth515's Avatar
2004 v6 mustang
Sorry by front pad i mean the outer pad. I am only referring to the rear rotors/brakes.
The outer pad on the driver side rear is really tight against the rotor and the opposite side very loose
I will check the rotor dimensions. I hope this is not the case because i doubt Advance auto will return the part. even though they were the ones who pulled the rotors from the back.
Old September 21st, 2011, 12:49 PM   #10
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
Maybe a dumb questions here, did you grease up the guide pins?
Old September 21st, 2011, 01:21 PM   #11
roth515's Avatar
2004 v6 mustang
yeah i greased them. Do you think they could have sold me the wrong guide pins. Because that's where i am having trouble fitting the caliper back onto.. its very tight and i have to pull the pins all the way in.
I am just trying to get an idea of what it could be, since i wont be able to work on my car until next weekend.
Old September 21st, 2011, 04:55 PM   #12
Moderator
2003 Grand Cherokee
It's possible. Do you have the old ones to compare to?
Old September 21st, 2011, 05:23 PM   #13
bluesmokesixxer's Avatar
2002 Mustang 3.8L
bluesmokesixxer will become famous soon enough
When I put new rotors on my car i found that it helps alot to once you put the new rotor over the wheel studs, spin on a lugnut or two to hold it where it is supposed to be while you put the caliper back on. Sounds like you have bigger issues but idk it helped me.
"Quit Bitchin' and drop the clutch"
Old September 22nd, 2011, 08:43 PM   #14
roth515's Avatar
2004 v6 mustang
Thanks for the replies guys, i compared the old guide pins to the new and they were way longer, Advance gave me the guide pins for the front. Got it all taken care of now.
Threads Similar to: New Rotors. RED HOT!!
New rotors TrueBlueGT2002 99-04 6 May 1st, 2011 05:03 PM
Debate! Slotted Rotors, Drilled Rotors, or Both? Mustang46 99-04 32 October 3rd, 2010 05:27 AM
New rotors pear0119 2005 - 2010 13 August 19th, 2009 09:59 AM
Rotors Rated_R 2005 - 2010 V6 5 August 13th, 2009 12:35 PM
Used rotors svt95gt 2005 - 2010 6 April 14th, 2009 08:10 PM
