car creeking
Old October 22nd, 2011, 06:23 PM   #1
2000 v6 mustang
1slowv6 will become famous soon enough
car creeking
car creeks when im turning if the car is moving slow or not moving and sometimes over speedbumps
i had the spring iso's taken off and i thought it was that so i put them back but it still creeks
also the power steering wines really loud but the fluid level is fine
what you guys think??
heres a video you almost cant hear the creek over the wine
If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
Old October 22nd, 2011, 06:28 PM   #2
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
Vid isn't working. But my suspension started to do this aswell. But i did the ball joint test on my car too see if those were it but the wheels didn't have any movement at all. I have absolutely no clue what is causing mine. but you may want to try the ball joint test.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old October 22nd, 2011, 06:52 PM   #3
Loki's Avatar
1996 V6
Loki will become famous soon enough
Power steering whine is normal with these cars for some reason .. I get it when I turn my wheel completely one way or the other. (Does it even when I'm parked, so it's not the tires rubbing anything.)
1996 3.8L.. Split Port Swap, CAI, True Dual Exhaust, the car accident mod.
Need cheap parts? CLICK MEEEEEEEEE!! =]
Old October 22nd, 2011, 07:00 PM   #4
2000 v6 mustang
i know the tires arent rubbing. and what do you mean ball joint test
Old October 22nd, 2011, 07:04 PM   #5
Green_6er's Avatar
2000 Mustang 3.8
jack the front end up, put one hand n top and one hand on the bottom and try to wiggle the wheel back and forth. if there is any play then your ball-joints are going bad.
Old October 22nd, 2011, 11:36 PM   #6
Macunicorn's Avatar
Macunicorn will become famous soon enough
Sounds like you might have a balljoint going out.
Sig by Tricep
Old October 25th, 2011, 08:28 PM   #7
2000 v6 mustang
ok i made a new video because its WAY worse now i cant do anything till sunday. its so bad its definately not tie rods or anything having to do with steering since its doing it when i push on the fender. all i can think of would be shocks, LCA, or balljoints idk im not a suspension guru
Old October 25th, 2011, 08:51 PM   #8
eleanorGT's Avatar
2001 Mustang 3.8
eleanorGT will become famous soon enough
I know my car doesnt bounce like that... mines pretty firm... could be bad shocks or something.. dont really know much in this subject, but i know my car is firm, and yours bounces
Old October 25th, 2011, 08:55 PM   #9
2000 v6 mustang
it bounces like a biotchh!! granted with cut springs... but still this is horrible
Old October 25th, 2011, 08:59 PM   #10
eleanorGT's Avatar
2001 Mustang 3.8
yea.. i dont think it should bounce at all.. it if you push down it shoudl recover pretty fast, not bounce a little, even with cut spring, it just lowers the car, it doesnt change the strentgh of the spring itself.
Old October 26th, 2011, 09:47 PM   #11
2000 v6 mustang
ok so shocks are not making this noise ( they NEED to be replaced but they arent the source of noise) they may be the cause of the part going bad but not the noise source.
inner tie rods are what seems to be the source of the noise. ball joints feel fine the boots are undamaged and there is no noise coming from there
so now lets say i wanted to do this asap
how difficult is the inner tie rod install. im gonna look up procedure tomorrow but for those of you who have done it. any suggestions?
Old October 26th, 2011, 11:41 PM   #12
Macunicorn's Avatar
What about like front arm bushings. Mine started to make a similar noise before I got mine replaced. Did you check those to make sure.
Sig by Tricep
Old November 1st, 2011, 12:24 AM   #13
iPoopke Regular
2004 Mustang
iPAPKE will become famous soon enoughiPAPKE will become famous soon enough
What macunicorn said, makes the most sense to me.
Old November 1st, 2011, 08:55 AM   #14
eleanorGT's Avatar
2001 Mustang 3.8
Agreed
Old November 1st, 2011, 01:16 PM   #15
Skar Gone
Skargon's Avatar
1998 Mustang V6
17.27@76.66
Skargon will become famous soon enoughSkargon will become famous soon enough
I Agree even though I didn't read anything and I seen two people agree.
Conformist.
1998 5 Speed, CAI, Exhaust, Rear Seat Delete.
Old November 1st, 2011, 03:07 PM   #16
eleanorGT's Avatar
2001 Mustang 3.8
LMAOOO... HAHA skargon... ur the man
Old November 1st, 2011, 03:13 PM   #17
Skar Gone
Skargon's Avatar
1998 Mustang V6
17.27@76.66
And on another note, it looks like he is humping the shit out of the Fender in the second video.
No wonder the car is screaming. D:
Old November 1st, 2011, 06:26 PM   #18
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
If it is the ball joint and its making that bad of noise, you would be able to see a tear in the rubber boot at this point.
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Old November 1st, 2011, 09:41 PM   #19
Green_6er's Avatar
2000 Mustang 3.8
i finally found out where the noise from my front suspension was coming from. Mine is actually coming from the passenger side of the steering rack.
Old November 3rd, 2011, 12:41 AM   #20
nasty02v6's Avatar
2002 Ford Mustang
nasty02v6 is on a distinguished road
When a mustang comes in the shop for a noisy front end I go straight for the lower ball joints. If the boot(s) is torn it's probably your culprit. I use a modified stethiscope to find the exact source of the noise. Alot of times the inner tie rods can also be the problem. The outer tie rod and arm bushings are the last thing I look at because they usually aren't the problem.
Bounce the car, if it's squeaking the whole time, probably lower ball joint.
Bounce the car while turning the wheels (you need a buddy), if it squeaks intermittently, probably inner tie rod.
Threads Similar to: car creeking
creeking front end on my 2001 jrfan4life 99-04 13 June 5th, 2010 04:58 PM
Creeking rack and pinion numbaonechief 99-04 4 April 14th, 2010 08:17 PM
