PRM's wont drop
Old October 27th, 2011, 07:18 AM   #1
bluestang1724's Avatar
03 cobra, 95 gt, 00 v6
bluestang1724 is an unknown quantity at this point
PRM's wont drop
after gettin the cobra i havent been driving the sixxer as much. but to save gas and miles i started driving the v6 to work again (it takes me an hr each way) well i noticed that when i let off the gas to coast it wont deccelerate like it should, and when i push in the clutch pedal the RPM's actually increase about 200-400 more and stay there till i come to a complete stop. the RPM's will sit over 2k and stay there untill i come to a complete stop. the pedal feels normal, and nothings feels wrong as far as the drivetrain.
2003 Redfire Cobra, 6-spd
1995 Laser Red GT 5-spd
2000 Atlantic Blue Metallic V6 5-spd
Old October 27th, 2011, 07:23 AM   #2
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
iac?
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old October 27th, 2011, 07:31 AM   #3
but wouldnt that affect the idle while sitting also? bc the rpm's are fine if im sitting still. and wouldnt the iac throw a code?
Old October 27th, 2011, 08:50 AM   #4
Dancing Naked In The Rain
mcqueen's Avatar
Yes and no. And no, there won't be any code for the IAC. When the IAC goes bad or gets very dirty, the RPMs get really screwy. Sometimes it will keep the RPMs high enough that the car won't decelerate on it's own, sometimes it will keep the RPM's high at idle (any time the clutch is disengaged and you're not pressing the gas), or sometimes it might have your RPM's drop really low and potentially stall the vehicle. I recommend getting a can of carb/TB cleaner, removing the IAC, and spraying it out really well. I did it a number of times on my V6 before it finally cleared up the problem.
My Hubpages
Hey.. r u really a tranny??
Old October 27th, 2011, 09:18 AM   #5
ill try that after work today. it doesnt deccelerate on its own. i have to ride the brake going thru the parking lot
Old November 24th, 2011, 10:08 PM   #6
Six Banger's Avatar
2001 - 3.8
Six Banger has a spectacular aura aboutSix Banger has a spectacular aura aboutSix Banger has a spectacular aura about
Bumping this for a question. My RPM's don't drop immediately when I press in the clutch (probably takes a good 3-4 seconds for them to go down at all) and after I come to a stop in neutral with my foot off the clutch, my RPMs will drop to ~500 and the car sputters and feels like its going to stall unless I give it gas. I assume it's the IAC, but I think I read somewhere that some you can clean and some you have to replace?
Also, where exactly is the IAC on our cars, I watched a couple vids about replacing them on GT's, it would be about the same place right? (Car is at college, I'm home so I can't check right this second lol)
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome.
Old November 24th, 2011, 11:21 PM   #7
mcqueen's Avatar
The IAC is on the upper intake, just past the TB, facing the firewall. Start by cleaning it (you might have to pull it off a few times before it finally runs right). If cleaning it a few times just doesn't do the trick, the IAC might be totally shot and then you would have to replace it.
My Hubpages
Old November 26th, 2011, 01:10 AM   #8
Six Banger's Avatar
2001 - 3.8
Okay, thanks for the heads up about maybe needing to do it multiple times
Old November 26th, 2011, 07:48 PM   #9
Green_6er's Avatar
2000 Mustang 3.8
if that's the IAC then what is on the intake just past the MAF facing the fender?
Old November 28th, 2011, 09:39 AM   #10
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
Intake air temperature
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old November 28th, 2011, 08:46 PM   #11
Green_6er's Avatar
2000 Mustang 3.8
mqueen said it was past the TB?
Old November 29th, 2011, 01:58 PM   #12
shipwreck_98's Avatar
2001 Mustang 3.8
shipwreck_98 is on a distinguished road
While you are cleaning the IAC, take a minute and do the same with the MAF and the Throttle body. The Throttle body might have a bit of varnish build up in there, spray some cleaner on a lint free rag and wipe around and inside the plate, that should help out a bit too.
Threads Similar to: PRM's wont drop
car wont start OBD II wont read. ECU? ForestGRN_Ghost 99-04 7 September 14th, 2011 11:38 AM
Please God... Drop it hard, drop it fast dr.gonzo! The Clubhouse 37 December 9th, 2010 12:27 PM
5.0 drop? smoke-em The Clubhouse 2 October 5th, 2009 11:58 PM
idle wont drop..Any Ideas superunknown23 V6 Mustangs 7 February 22nd, 2007 02:38 AM
